Question about Canon PowerShot A540 Digital Camera
Can not remove MEMORY CARD from canon a540
It locks and unlockes fine, however it will NOT come out of camera. Feels like it is hitting a STOP?? Push down, it locks in place, push down again and it pops up a short distance, and hits a stop???? Have pulled pretty hard on card. Camera works fine. thanks in advance
  • ss1 May 09, 2009
    It took a pair of pliers to get it out. IT WORKED and the camera still works! much thanks
    Sniper:
  • 61 Answers
Pull it harder. You obviously don't want to break it but if it still doesn't come out, I would look for screws and try to take the camera apart. Take the battery out first and don't forget how it goes back together and it should be fine.
Posted on May 09, 2009
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
Locked card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 23, 2012 | Patriot Sd Card 2gb Memory For Canon Power...
My memory card is locked and i tried everything i have a canon a540 powershot and the memory card is a sandisk 8gb
Have you noticed the slider on the side of the card? This acts as a lock and might have been accidentally moved to the locked position, in which case you could just move it back to unlock again. Hope this helps.
Dec 27, 2010 | Canon PowerShot A540 Digital Camera
Canon powershot A540 I have tried to erase memory card but it says card locked. How do I unlock.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2010 | Canon PowerShot A540 Digital Camera
Memory card locked. Will this camera support SDHC cards or just SD cards
The A540 uses SD cards, not SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 01, 2010 | Canon PowerShot A540 Digital Camera
Memory card says "card locked"?
There might be a little switch on the side of the memory card that allows it to be locked. Just unlock it, and it should be fine.
Oct 16, 2010 | Canon PowerShot A540 Digital Camera
Memory card locked
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Feb 07, 2010 | Canon PowerShot A540 Digital Camera
Canon powershot A540 digital ...problem it shown card locked
Remove the SD card from the camera. Look for the tiny slide switch on the side of the card. Slide this switch back to the unlocked position (opposite of whatever its at now).
Aug 01, 2008 | Canon PowerShot A520 Digital Camera
There's a little switch on the side of the SD card. Remove it from the camera and find the switch. Normally, there's some very small printing next to it saying something like (Lock / Unlock).
Mar 27, 2008 | Canon PowerShot A540 Digital Camera
I had the same problem with a card in my power shot A540. on the side of the card there is a little white slide-bar. Push that bar the opposite direction of where it is and see if that works. Good luck!
Jan 08, 2008 | Cameras
Canon PowerShot A540 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
