Question about Waring WCT708 4-Slice Toaster
Toaster lever wont stay down
When i pull the lever down to begin the toasting process, the lever wont stay down so the carrier wont stay shut so i cant toast my toast.
  • 1 more comment
  • sparkydi Dec 22, 2007
    sprayed electraclean on contacts right side working fine left not responding wont stay down. Did get it to stay but it would not release after hitting the right temp then just stopped working.
  • Anonymous Mar 14, 2014
    I push the lever down to have the bread toasted, but it does not stay down. What to do?
  • Anonymous Mar 24, 2014
    WONT STAY DOWN, DOESN'T HAVE SCREWS
    Problem Solver:
  • 11 Answers
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
  • rickhan Oct 01, 2011
    An electromagnet holds the nylon hook down over the lever. Seems that, over time, the electromagnet gets weak for some reason. Nothing is broken off or stuck. Hate to trash a toaster for such a small part.
  • Rob Sorrentino
    Rob Sorrentino Apr 10, 2014
    I have the same problem. The magnet is not working Is there an answer?
SOURCE:
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
My toast lever wont stay down-I've loosened the cover and cleaned as best I can. How can I take the lever off so that I can fully remove the cover? It is a Cuisinart two slice black toaster.
On most appliances the knob on the lever pulls off and the cover is then lifted off the lever. Check that the bi-metal strip that latches the toast ejector has not been bent or damaged. Once you have the cover you will be able ot see the whole mechanism.
Jan 26, 2011 | Cuisinart Kitchen Appliances - Others
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
Lever on toaster will not stay down
For what it might cost to fix it buy a better brand of toaster for about 10% of the cost of this horrible brand.
You'll notice their new ones are "smart" toasters with NO LEVER. You push a button and the electronics takes care of the rest (and blow up quickly.)
$15 to $25 at Walmart.. instead of $100 to $200.
Dec 13, 2017 | Breville Kitchen Appliances - Others
Toast wont stay down in toaster it wont lock in place
I'm at the same crossroad. Thry holding down the lever for more than 4-secs. The light will blink once, then it is as though the circuit is over-ridden and a toasting cycle will begin. This might help to eliminate wether you have a mechanical or electrical issue. Mine appears to be electrical. I'm now investigating if it is the timing or relay?
Jul 15, 2009 | DeLonghi CTH4003 4-Slice Toaster
The digital control panel is on the fritz,
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Nov 28, 2008 | Oster 6330 4-Slice Toaster
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
Dec 27, 2007 | Kitchen Appliances - Others
Waring WCT708 4-Slice Toaster Logo
4,802 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Jim
Bruce Eichhorst
Ps Daengr
Ps Daengr
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
