Question about Pass & Seymour Pass Seymour 90611WV 600W White SP Rotating Dimmer
Install dimmer switch and plug
Have a wall wired vanity I want to turn into plug in light with dimmer switch
2 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: how to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Posted on Apr 09, 2010
All interior lights and trunk light will not come on.
There is a fuse for these. Fuse good and has power to it. Look at replacing the light/dimmer switch. If the fuse is good, you need to check for power at the switch plug. Could be a bad wire.. Power or ground.
Sep 03, 2016 | 2004 Volvo S40
Vanity cabinet with lights needs power
Dimmer wires in series on either wire of the cord.
Nov 27, 2013 | Pass & Seymour Pass Seymour 90611WV 600W...
I am installing a Leviton 7299 smartlock pro gfci combo switch. I am also installing a new vanity light. I have 2 wires coming in. One from the panel box and the other going to the new vanity light. I have...
run a jumper wire from brass load on gfi to top screw on switch then the black wire from light to the other screw on switch, white wire from vanity light should be connected to silver load screw on gfi WILL NOT WORK IF NOT GROUNDED PROPERLY if your ground is connected to common (white) in your breaker box this could cause issues also. a sure ground is the plumbing in your house. if you have copper lines you can use a saddle connector to ground the gfi, if these options are not available contact an electrician in your area.
Jul 04, 2012 | Electrical Supplies
I want to use a TM8111 swithch to control 3 devices. A ceiling fan/light combo, night light and a vanity light. How do I hook it up?
Following image has basic wiring plan.
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Each Load (light-or-fan) has to have separate wire running to switch box.
If night light is plugged into wall outlet, then a new wire will have to be added going to switch box.
Most night lights have built in photo eye, and on-off switch.
Add a comment for more help and include specific wiring and what you have tried so far.
Jun 14, 2011 | Pass & Seymour Legrand TM8111 Three Single...
I have installed a 2-way dimmer switch in my dining room. I was able to install it and it works great. However, on the other side of the wall where I installed the switch, I have another single way...
If I understand correctly new dimmer is in different box than outdoor switch.
And outdoor switch controls different light than new dimmer.
Both new dimmer and outdoor light are on same circuit breaker, and that breaker is not tripped.
Outdoor problem could be related if loose wire inside dimmer box also feeds over to outdoor switch. More below.
Here's how I would troubleshoot problem.
1) Check outdoor bulb(s). This step can be big time saver.
2) Pull outdoor switch out of box a bit so you can see and test wires.
3) If wires are pushed into quick connects located on back of switch, these connects get loose. Moving switch usually causes loose wire to connect again, so turn switch ON-OFF and see if outdoor lights work. Sometimes switch works fine after quick connects reconnect. If quick connects are bad, use tiny screwdriver in slot next to connect-hole to release wire. And then connect wire to screw terminals on switch. Or replace switch.
4) Turn switch to OFF, use tester and test both screws on switch to bare ground wire. Tester should light up on one screw. If tester does not light up, then switch is not getting power, and that wire has to be tracked back to see where short is.
a) Look if one of the black switch wires is connected to other switch, or connected to other black wires inside same box. This wire might have come loose.
b) Look at white wire inside same box and make sure they are twisted together and covered with wire nut.
c) Now here is where dimmer could be related ... if white wires are joined together in dimmer box, they could have come loose if they were not properly twisted together and covered with wire nut.
http://waterheatertimer.org/How-to-twist-electric-wire.html
5) Turn switch to ON and test again. Tester should light up on both screws. If switch does not light up on both screws, then switch is bad. Replace switch.
Add a comment if you need more help.
Dec 01, 2010 | Leviton Decora Light Dimmer Switch
The task was to replace a bathroom vanity light. Before removal of the old light, the dimmer switch worked correctly. I didn't touch the dimmer switch. After removal, the wall wires consisted of two...
Alan
Generally, 3 wires indicate a "3way" switch where you have 2 switches at opposite entrances to a room. Both the Red and Black Can be hot, depending on the other switches position. But, a red wire would normally only be found at the switch box not the light.
What I'd suggest, is that you get a multimeter, and use it to determine the hot wire and the ground/neutral. Once you know which wire is hot, connect the hot to the black lead, and ground/neutral to the white lead of the light. That is the only SAFE manner I can see to resolve this.
Mar 02, 2010 | Electrical Supplies
I'm installing a vanity light in the bathroom. The old one had a dimmer attached. For the new fixture, attached two white from the wall to the white in the fixture. attached two white from the wall to...
Get a test light, a bulb in a socket with a black and a white wire. disconnect both the black and the red. Also have access to the white or the ground. Then with the power hold the white test light wire to the white of the house and the black to the black. .turn the dimmer on and off and see if it controls the light. NEXT do the same with the red, that is test light black held to red and test light white held to house white. once again check the dimmer.
Typically when you have a hot red and a hot black in a fixture the black is on the dimmer and the red is always on because it is connected to an outlet built into the light. OR the light can be controlled from two locations, one regular switch and one dimmer switch.
Mar 01, 2010 | Electrical Supplies
I'm using a Leviton 1755 combo 3 switch for a bath light/fan combo and then onto a vanity light. Basics: wires from ceiling light/fan: black, red, white, ground. Wires to vanity light: black, white,...
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Feb 22, 2010 | Leviton 003-1755-W Three Rocker Switches
Lustro Maestro MA-LFQHW-WH Fan/Light Dimmer
something is messed up for sure... two solutions.... disconnect outlet and cap wires.. or open up both boxes and see where / how they they wired the outlet into the fan/ light control and disconnect it there and then pick up power for the outlet from the black /white wires BEFORE the dimmer control
Aug 19, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Voltage on dimmer switch constant
That red wire is hot, it's used in what is called a 'switch loop'. That's where the electrician will bring the hot for the circuit to the light first, then run down to the switch and back with the switched hot for the light. Turn the breaker off!
Jul 09, 2009 | Leviton Decora Light Dimmer Switch
Pass & Seymour Pass  Seymour 90611WV 600W White SP Rotating Dimmer Logo
27 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Ottoniel
Mike
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
