Question about Miele Washing Machines
Miele w 485
My 12 year old Miele washing machine (W485) makes the most terrible loud noise when spinning and there is a strong smell of burning. Will it be worth having it fixed or more cost effective for me to buy a new washing machine?
  • 78 Answers
SOURCE: Burning smell when my Maytag top load washing machine is running
Sounds like the belt is sliping. ether it's loose, or the trans needs lubed, or both.
Posted on Jan 14, 2009
mgprice
  • 744 Answers
SOURCE: Loud clacking sound from the washing machine as spin cycle starts
Yes you either have a whirlpool or kenmore...since you didnt mention the make I guessed :) It sounds like you have a bad coupling, have included a link giving you instructions for replacing the coupling and a link where you can buy the coupling.
http://www.thisoldappliance.com/howto/Motor_Coupling.htm
p.s you don't actually have to remove the cabinet, the motor, pump and coupling can be accessed by tilting the machine back and wedging something under it so it does not fall on you while your working on it.
you can purchase the part from:
http://www.appliancepartspros.com/part_details.aspx?part_id=3963893
Hope this helps.
Posted on Jun 23, 2009
SOURCE: making loud noise in the spin cycle and now does not spin at all
I have a 1998 model and the tub bearing was the problem with the same symptoms you have provided. I purchased a replacement (genuine Maytag) outer tub in 2007 and that fixed the problem. The old bearing was pulverized. The tub was 239.65. I got the parts from "Repairclinic.com>" I also replaced the door boot for 57.80. Today my spin/agitation cycles quit! The belt is ok but I haven't looked beyond that.
Posted on May 08, 2010
barkencoa
  • 3463 Answers
SOURCE: hi my hotpoint washing machine is near 3 years old
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Posted on Jun 16, 2010
  • 70 Answers
SOURCE: 10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Posted on Jun 19, 2010
While spinning, it made a loud noise but finished washing the load while continuing to make the noise especially while spinning fast.
Hi Chantal,
In my many years repairing Miele machines - the most common problem for what you are describing is the underwire from a bra has got in between the inner and outer drum. It's tricky to get out and can be done if you are good with tools and a little technical - but it does involve opening up the machine, removing one of the heating ellements and searching / fishing it out. Another less common reason for this rubbing noise could be the metal heater element bracket that also sits between the inner & outer drum, has bent - but this is normally caused by a bra underwire. Hope this helps.
Sep 14, 2015 | Miele Touchtronic W1213 Front Load Washer
When not in use Miele washing machine tapping noise
Hi.
I need more info from you.
What model is this machine? How old is it?
It is possible that the sound comes from the water dispenser valve selector. If you could give me more info about your Miele machine, it would be helpfull.
/ Geir
Miele Technical Engineer
Sep 27, 2014 | Miele Washing Machines
Loud grinding noise meile washing machine drum when spinning?
It can that the spin drum is touching the body if not you can leave it until its broken my machine is doing tht also
Sep 17, 2014 | Miele Washing Machines
Why does Miele w2515 makes loud banging noise when it is about to spin?
See if you can level out the unit. Sound like the case is responding to un-even pressures.
May 23, 2014 | Washing Machines
My miele, is 6yrs old , no problems in past, new bag and filter, after using for roughly 10 mins, i can smell a strong burning smell, any suggestions how to fix this please , regards zoe
Hi Zoe,
The strong burning smell is almost always an indicator of a motor being burnt out. I have made a Miele repair video but am not sure which model you have so it may not be exactly what you need.
Aug 13, 2013 | Miele Vacuums
Washing Machines Logo
27 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
