Question about Procom SSU320RHN-GB Heater
I need replacrement remote for SSU320RHN
Pro Com vent free gas stove
  • 17 Answers
SOURCE: Too much sweat is on my windows in cold weather.
Vent free is the problem, 1 of the combustion byproducts is a large amount of water vapor. Crack a door to the room a little and maybe even a windw slightly (as it most likely states in the owners manual) and see if the problem goes away.
high himidity + warm air+ cold window glass = condensation
fresh air circulation = less condensation and also less CO and other bad things in the air you are breathing...just because its vent free does not mean its not dangerous in a tightly closed room. The vent frere designation assumes a certain number of air changes per hour and you are not getting them.
Posted on Nov 14, 2008
Ks-landlord
  • 4 Answers
SOURCE: Pro Com QD250T can I install directly to a 4 gal. Propane tank
You should not have the Tank in the house , it's like storing a bomb in the house . for more info call 1-866-886-5989
Posted on Jan 14, 2009
  • 188 Answers
SOURCE: lost my remote control and need a new one
Contact Master Parts at 800-446-1446 or online at www.masterparts.net. I hope this helps!
Posted on Jun 30, 2009
billyvangogh
  • 108 Answers
SOURCE: I'm looking for the phone number for the company
Remote receivers are always a problem...I would get rid of that....you can work it manually with the on/off knob by jumpering the 2 contacts that the remote was using...or you can run 2 new wires from the same contacts and install either a switch on the wall or a thermostat...if the wires are burnt I would also check and make sure the Vent/chimney is functioning properly and not plugged before putting it back into operation
Posted on Oct 25, 2009
  • 23 Answers
SOURCE: I just installed a brand
Is the pilot light a nice blue colour, is it noisey only at start up. Could be air mixture on pilot and pressures not set correctly
Posted on Dec 15, 2010
How do I resync my ProCom remote with my ProCom Vent Free Fireplace? I have an older model, SSU320RHL-GB.
I ran into this same problem yesterday while I was trying to get my used unit up and functioning.
If you don't switch from pilot to off and wait about a minute before turning it to the "electric" mode, the remote will NOT light the unit.
Oct 24, 2014 | Procom SSU320RHN-GB Heater
Does a Maytag gas stove model # CRG9700BAL have to be vented. Im replaceing a stove that quit working with this one and it has no vent, but my old one did.
Old gas stoves were designed to be vented out. the newer stoves vent out the top at the back of the top panel. You may still need to have some kind of vent in the kitchen either a ceiling vent van or a range hood. At the very least a window in the kitchen. You may want to check with the local building codes about how to vent the stove and the requirements.
Oct 01, 2014 | Maytag Kitchen Ranges
SSU320 remote appears to be dead. New batteries do nothing. I tried the reset instruction with no luck. Can;t seem to find replacement remotes online
Marcus, here is a link to where you can find 2 different type of remotes for your stove. Both are manufactured by SkyTech, a respected manufacturer in the hearth industry.
http://www.dixieproducts.com/remotes.html
Either remote will work for your application. Just depends on how simple or advanced you want it to be.
Hope this helped you and thanks for choosing FixYa.
Sep 16, 2011 | Procom SSU320RHN-GB Heater
I have a SSU320RHL-GB the unit works well in the automatic mode with the remote but when you try to go to the manual override the pilot will not stay lit, it lites but will not stay lit. It is very...
That is very odd. I've been in the hearth business for 15 years and have never been faced with this problem. Although, I suspect the remote receiver box is the is the culprit. To test this theory, turn the receiver box OFF. If you're unable to do that, remove the batteries from the receiver box and try operating the stove manually. If it then operates manually, it may be the reciever is wired incorrectly or the 3 position rocker switch on the stove, needs to be switched from Remote to ON. That would then override the remote receiver.
Hope this helps you and thanks for choosing FixYa.
Aug 18, 2011 | Procom SSU320RHN-GB Heater
I bought a Vermont Casting Radiance Model 2240 Gas Stove 10 years ago. The fan makes a horrible noise. I have a manual, but the fan page says the fan is optional and page 1 is missing. Also page 2 is...
Finding an match to your Owners Manual is difficult at best. As, Vermont Castings has gone through 2 different corporate ownerships in 10 years. However, for the most part, their castings and the mechanics for the Radiance model have pretty much stayed the same. This gas stove was manufactured in a Vented and a more efficient Vent-Free model. The installation of the fan was different for each model. Since you didn't specify whether you have a Vented or Vent-free model have included the Owners Manual for both. Keep in mind, these manuals are for the stoves that currently being produced, but the installation is very similar. You will be removing the blower rather than installing it, so do everything in reverse.
Vented Model http://literature.mhsc.com/vermont_castings/manuals/30004967_RADVTCS_5.pdf
Vent-free Model http://literature.mhsc.com/vermont_castings/manual/30005056_Radiance_VF_5.pdf
If you need to replace the blower, you can purchase one from an authorized VC dealer in your area. To find one go to http://www.vermontcastings.com/contact.asp
Mr. Whaley, I hope this helps solve your problem.
Mar 21, 2011 | Heating & Cooling
I'm looking for the phone number for the company. The wires to the remote receiver are burn't. Lost the manual, and there are no numbers on stove except the SSU320RHN-GB model.
Oct 24, 2009 | Procom SSU320RHN-GB Heater
Remote not beeping or lighting stove
Sounds like you may have a similar problem that I have. I found a cable that attaches to the remote receiver melted to one of the gas pipes behind the panel. Poor design, should have been insulated. My heater just beeps, with red light flashing.
I just posted looking for the phone number for the company. Lost my manual, and need to contact them. Can anyone help?
Feb 28, 2009 | Procom SSU320RHN-GB Heater
Procom SSU320RHN-GB Heater Logo
102 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
