Question about IBM Personal Wheelwriter 2
My wheelwriter will turn on but then it's frozen. None of the keys work. The carriage won't slide back and forth. It's pretty much dead in the water. It was serviced and cleaned less than a year ago. Anxious to see if the problem is something that I am able to fix.
  • 3594 Answers
SOURCE: My IBM Selectric System 2000 Wheelwriter
The plastic cap on the print solenoid is probably broken. We sell them with installation instructions for 20.00 including shipping. DickyO Cleveland Business Machines 216-241-0027
Posted on Jun 04, 2009
  • 3594 Answers
SOURCE: IBM Wheelwriter 10 (Ser II) Frozen w/ Blinking Indicator Lights
Try reinstalling the printwheel.
DickyO
Posted on Jun 23, 2009
  • 3594 Answers
SOURCE: IBM Wheelwriter 5. Beeps once when turned on,
Try reinserting the printwheel, check for debris in the printwheel area.
DickyO
Posted on Jul 06, 2009
  • 3594 Answers
SOURCE: IBM Wheelwriter 15 beeps on the sixth keystroke
It sounds like the R. margin is set at that place. Space to the r. as far asd you can and press the R. margin key on the left side of the keyboard.
DickyO
Posted on Jul 30, 2009
  • 3594 Answers
SOURCE: IBM LEXMARK WHEELWRITE 5 TYPEWRITE NOT TYPING
Be sure the print wheel is properly installed and that there is no debris in the P/W area. otherwise you'll need a tech.
DickyO
Posted on May 21, 2010
Carriage will not return on 2 of our IBM Wheelwriter 6, can this be fixed?
First spray some WD40 on the silxer shaft that the carrier slides on they get really gummy, if this works run it back and forth a few times then clean the shaft off with a rag.
DickyO
Jun 25, 2015 | IBM Wheelwriter 6 Typewriter
Carriage return stuck on left side when powering on
The first thing to try is to lubricate the silver rail that the carriage rides on. A few drops of a light oil ( sewing machine oil ) may take care of the problem. Turn machine off, apply oil and move carriage by hand back and forth. Turn back on and see if this took care of it.
May 14, 2013 | IBM Wheelwriter 6 Typewriter
IBM Lexmark typewriter carriage return won't return to left position
Hi:
Open the top cover and locate the shiny rod that the carrier moves back and forth across. Use some WD-40 on a rag to clean it well the apply a light coating of it to the entire shaft.
Jun 21, 2012 | IBM Wheelwriter 1500 by Lexmark Electronic...
Olympia Startype electric typewriter , make a funny noise and won't move carriage. Can not get it to work.
Turn it off and see if the carrier will move back and forth by hand if it will but feels a little gummy spray a little WD40 on the silver shafts that it slides on. If it won't move by hand look for debris in the carrier area.
DickyO
Sep 19, 2011 | Olympia Office Equipment & Supplies
IBM Wheelwriter 6781 won't perform a full carriage
Spray some WD40 on the silver shaft that the carrier slides on. If this doesn't work Spray some on the carrier motor bearings, located under the case R. rear corner. You can access the front one from 9inside the rear you will have to fish the straw thru the case.
DickyO
Aug 04, 2011 | IBM Office Equipment & Supplies
DickyO
May 19, 2010 | IBM Wheelwriter 6 Typewriter
I TURNED IT ON AFTER A LONG PERIOD OF NON USE. AS
Dosen't sound to good. While it's off try moving the carrier (print head) back and forth it should move freely if not put some WD40 on the silver shaft it slides on.
DickyO
Feb 09, 2010 | IBM Wheelwriter 30 Typewriter
Carriage won't return all the way to the left- almost as if a left margin has been set. Help.
if margin clear doesn't work try putting some light weight oil on the rails the carriage rides on. turn unit off, oil it and move carriage back and forth by hand then turn it on and see if that fixes it.
Nov 25, 2009 | IBM Wheelwriter 30 Typewriter
Carriage return not working
Turn off T/W and see if the carrier will move back and forth freely, if so try removing the batteries and unplugging the machine this will reset to defalt settings. CAUTION THIS WILL ALSO CLEAR YOUR MEMORY!! If the carrier is hard to move a little light oil on the shaft it slides on may cure the problem.
DickyO
Mar 25, 2008 | Lexmark Wheelwriter 35 Series II...
IBM Personal Wheelwriter 2 Logo
80 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
