Question about Vacuums
Electrolux vacuum model c141b
I have a model c141b vacuum there is a clog near the handle. How do I take the handle apart
LizDahl
  • 75 Answers
SOURCE: electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Posted on Jan 12, 2008
reddevil6
  • 1673 Answers
SOURCE: How do we open this vacuum?
Some of these, the strip on each side, in the middle, slide off, then the 2 halfs will separate. They only slide in one direction and some are hard to get off.
Posted on Mar 10, 2008
  • 4 Answers
SOURCE: Electrolux Central Vac Hose Clogged
John,
There are several handle types. The pump style has about 8 phillips screws that hold the handle together. Make sure it is not connected to the wall as some have 120V cords or direct connect pins to supply power to a motor driven brush.
The two halves will separate and if it has slip rings the tube will lift up out with the hose.
If this is a low voltage hose, there are three tabs at the base of the handle you press in and pry out the end piece. You will need to remove the switch contacts before the hose will pull out. Remove the phillips screw that holds the switch trim in place and lift out. This will allow the cover to be removed to lift the contacts off the slip rings and the hose will drop out.
Hope this helps!
VR
Posted on Nov 18, 2008
  • 5 Answers
SOURCE: Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Posted on Nov 22, 2009
  • 430 Answers
SOURCE: I have an older Electrolux canister vacuum - model
Check to be certain the thermo lite is on and not the bag full indicator. The thermo detector is very reliable, but the bag fill valve often fails. If it is the thermo, check your hose and wand for blockage by dropping a coin through them,before opening the vac itself.Otherwise you may have a bad set of motor bearings causing the motor to overheat due to its age.
The 2100 and all its canister cousins made since 1982 seem to be prone to failure of the dial valve on top cracking internally. The causes the bag full indicator to come on and the vac to shut down.
To open the vac you will need to slide the locking keys and bumpers forward with the bag door open. Do this with a set of pliers. Once done the vac will open from front to back like a **** shell. Be careful to look at the underside hinge are of the bag door before separating and mark and locate the wiring harness . This vac only goes back together one way, perfectly assembled it pops together with ease. If any piece is out of line it`s like a RUBIKS Cube. Take your time . OEM parts are only available through an AERUS Elctrolux dealer or repair shop
Posted on Dec 15, 2009
My upright electrolux vacuum will not suction from the wand. How can I fix this?
HI, it's Jim from Crucial Vacuum!
If your Electrolux vacuum is losing suction from its wand then most likely there is a clog in your vacuums hose.
Stretch out your vacuums hose as far as you can to unblock any clogs. If there is a clog in a hard to reach spot try using a broom handle to reach the area.
Another area to check is your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction for your vacuum. Empty your dust filter after every use to promote optimization in your suction.
You can purchase replacement parts for your Electrolux vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=electrolux&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 08, 2015 | Electrolux Vacuums
Shuts off (overheats) after 10 minutes. Protecto relay? How to take apart?
Your machine is what's called a "Special Model" and needs to be disassembled upside down in a form fitting tray, by removing the two side rubber bumpers, then taking off the bottom and finding the part that shuts it down. The best thing to do is to take it to an Electrolux repair shop and let them handle it. They have the trays and they're trained in the way it comes apart properly;
Nov 09, 2013 | Electrolux electric hose models 2100
I have an epic 6500 sr. I need to take apart the handle on the wand to clean it (I unknowingly vacuumed over a puddle of urine, yuk!) It is a replacement wand. I've unscrewed the only screw I can find...
Look on the handle near the wand handle release button for extension and there is a little round cover, under that is another screw...usually it is a tamper proof torque screw.
Oct 16, 2013 | Electrolux Vacuums
How do I get the hose apart on an electrolux canister
Unplug it from the canister and try reconnecting it to the blower connection port
Mar 11, 2012 | Electrolux Guardian Bagged Canister Vacuum
My electrolux ultraone keeps cutting out after a couple of minutes - there are no lights indicating filter or bag?
This is not an Electrolux Lux 7000. Totally different companies.
However, check the hose for clogs. Drop a coin down one end and lift so it should drop out the other. If it doesn't, there's a clog that needs cleared. This can often be done by pushing it out with a broom handle.
Jan 26, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
We have suction at the outlets but when we plug the hose in we have no suction at the carpet vaccuum head.
Is there suction at the end of the hose? If not, the hose is clogged. Generally the blockage is located near the handle, but sometimes at the other end. Occasionally, if something long, like a straw, is sucked up, it will get caught somewhere else in the hose that's impossible to get to.
You can try to hold the wand end of the hose directly to the CV tank and turning it on. This should clear the clog. If not, hold the handle end to the blower of a shop vac or canister and turn it on. The other end should be either in a large plastic bag, inserted in the in port of the vacuum, or directed outside.
If there is suction at the end of the hose, the most likely place for a clog is at the elbow on the power nozzle or just behind the brush. This can be cleared by using the handle of a wooden spoon or similar blunt object to push the clog back out toward the brush.
If none of these help, take the vacuum to the nearest Aerus Electrolux store for assistance.
http://www.aerushome.com/storelocator/
Jan 16, 2011 | Electrolux Central Vacuum
Sep 28, 2009 | Electrolux Vacuums
How do you take the handle apart?
Take a box cutter blade or something razor thin and locate the 2 screw covers on the handle. Pry the two covers off and remove the 2 hex screws. Pull handle apart. Done. Might want to check your elbow down on the power nozzle before you rip apart that handle though. 4 out of 5 times, the problem is in the elbow.
Jul 10, 2008 | Electrolux Epic 6500 Vacuum
Eleectrolux canister sweeper power switch
There should be screws holding the handle asembly on to the top. One near the from, another by the handle, then slide the door near the back, there are 2 more screws there. with the handle off, you can get to the switch. Hopefully you can fina a replacement, alot of parts for the older Electrolux is No Longer Available.
Feb 12, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
