My LG WD8015C is not spinning. It seems to be sparking near the motor
2 Suggested Answers
SOURCE: Front loading machine washing but not spinning.. LG WD8015C?
Sounds like a problem in the selector switch.
Gillight
Posted on Jun 22, 2012
Intellowasherlg wd8015c is not spinning. When it try's it makes a screeching noise and you can see a flash underneath
There is a major problem with the drive motor. Get a good DIY person to have a look or call an appliance engineer. Unplug it before you remove any access panels. Water and electricity don't mix.
Jun 02, 2015 | Washing Machines
LG Washer/Dryer Combo not spinning
If you can make the motor spin a few revolution by manual intervention, then the issue is most likely a faulty motor 'start' capacitor which is located near the motor: this replacement involves a dangerous MAIN AC VOLTAGE device and I would advice getting a qualified technician to check/repair your dryer.
Hope it helps.
Apr 06, 2014 | LG WM-2277HW Front Load Washer
Have a 7.5 Kg Fuzzy Logic top Loader that does not spin
Hello.. DE Error means door error but if wash cycle is working properly means you need to change your drain motor.
Feb 13, 2018 | LG Washing Machines
Lg intellowasher 7kg wd8015c
OVER LOADING YOUR FRONTLOAD WILL DAMAGE CENTER CARRIER BEARING
Aug 17, 2013 | Washing Machines
LG dishwasher will not drain
wow !! you sure seemed to be very through in your troubleshooting , but one thing I read that you did not see/test was the drain solenoid valve , this is a medium size valve just near the pump that opens to drain line from pumps discharge to allow the water to exit the machine , otherwise it just gets to go up and around the machine again , these especially on "used well" machines tend to rust up and stop moving , a new replacement and there off running again
Mar 02, 2017 | LG LDF7932ST Dishwasher
Front loading machine washing but not spinning.. LG WD8015C? any ideas
Gillight
Jun 22, 2012 | Washing Machines
Lg DLE3777W wont start
if the motor is running and the drum is not spinning check the belt that wraps around the drum and motor. may have broke or just slipped off
Jun 21, 2012 | LG DLE2512W Electric Dryer
We have a LG WD8015C front loader. Today it has decide not to wash clothers. The machine does not take in any powder from the full out tray. And water remains in the machine and does not drain out. It...
check the pump first............get machine to an open door......let the hose lie outside,......this will get the water out the machine....
check the pump for a blockage.......then try again....
cheers
Aug 18, 2017 | LG Washing Machines
Wont start.
If it will turn over check to see if its fuel or fire. To check for fuel, spray quick start for a few seconds into intake. If it starts and stops. its fuel. Change fuel filter and check fuel pump. If it does not start its fire, Could be distributor cap, rotor, coil, spark plug wires or spark plugs. If it does not turn over it could be battery or starter. Check battrey connections, ground strap from motor to body and ground wire from battery to motor and body.
Jul 26, 2010 | 1995 Honda Civic
Washing Machines Logo
Top Washing Machines Experts
