Question about Motorola Audio Players & Recorders
Motorola dch70 - Motorola Audio Players & Recorders
What is the motorola comcast cable box code for remote.box is DCH70/2081
0039,0031,0038.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 24, 2014 | Toshiba Ct-90302 Remote Control
RCA entertainment series TV does not show the entire image
Check the picture settings. It sounds that the picture settings to TV is Zoomed.
May 29, 2012 | Televison & Video
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
Dec 07, 2010 | Motorola Mobility W375 Cellular Phone
I'm having trouble connecting m dch70 cable box to me phillips vcr and television.
the wire from the wall / outside is connected to (in) on the cable box... short cable wire connect to (out) of cable box to (in) on vcr another short cable wire connect to (out) of vcr to the tv....Note both the TV and VCR must be set to Ch 3 and TV source will be cable not air....
feel free to rate help
Sep 06, 2010 | Televison & Video
I have a motorola dch70 cable box from comcast. I recently hooked it up and set it on top of my TV. I cannot get any info on channels or any info when I hit guide. If I hit the ondemand button it says...
you say that it works if you move it away from the tv set, its due to the electrical interference of the high frequency internal tv signals with that of cable box, you need to shield/reduce the interference by either moving the box away from tv set or placing the box on a grounded metallic plate on the tv set
Jul 29, 2010 | Televison & Video
TRYING TO INSTALL DIGITAL SET-TOP BOX WITH DVD AND TV
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
I am in South America. I am into the TV cable business. I need to copy the tvcable company software from one Motorola DCT2200 that had already it store by the cable copany to a brand new box...
Hello there:
here isa weblink that may be able to help you out for what you need ok
be
Motorola Motorola Online Motorola Motorola Motorola : Motorola motorola bluetooth adapter pc850 software. motorola bluetooth adapter syn0717a driver ... motorola dct2200. motorola dct2224 troubleshooting. motorola dct2224 ...st regards michael
Sep 10, 2009 | Televison & Video
Lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Mar 07, 2009 | Samsung LN32A330 32 in. LCD TV
22 people viewed this question
Top Motorola Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
richie46
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
