Question about Maytag Dishwashers
How do we winterize a maytag dishwasher for 5 months per year
We turn off all utilities for winter. temperatures reach 0- 10 F.
turning on heat is not an option.
marked
  • 6487 Answers
SOURCE: cold air will not turn on
This problem of yours should be handle by a professional on heater/cooler trying to repair it by yourself will just cause more damage because you should have a knowledge about this device so better ask a repir guy or take it to a repair center near you to avoid any problem with it...
Good luck.......
Posted on Jun 23, 2008
  • 41 Answers
SOURCE: winterizing a LXIH Hobart dish washer
hi i am a hobart certified tech the only way to cancel your delime is to cancel this function in the service mode. also you must crack open the fill valve on parker valve and let the water leak out of the bonnet or the valve will split when it freezes
Posted on Dec 07, 2008
  • 71 Answers
SOURCE: MY GAS OVEN TOOK 2 HOURS TO REACH THE DESIRED TEMPERATURE OF 350.
the ignitor is prolly bad (not pulling enough amps)
Posted on Dec 24, 2008
SOURCE: freezing temperatures effect on LCD television
Just spoke with a vizio tech and they said the temp to operate is 41 degrees F. As long as temps don't go below -4 degrees F your tv should be ok. But if you are going to turn it on the temp needs to be no lower than 41 degrees F. I would let the room and tv warm up to at least 65 to 70 before I would turn it on.
Posted on Jan 16, 2009
  • 126 Answers
SOURCE: left tv unplugged for a few months no tv won't turn on
The first thing to do is try to turn on the set with the remote and then when it doesn't respond go to the set and hold down the MENU and INPUT buttons at the same time until the power LED starts blinking a two sequence code. Like 2 - 4 or 1 - 2. The code will keep blinking for five or six times and stop. The blinking is the microprocessor telling you why the set is not working. We techs call that a self diagnostic function. Which this set has. Just repost your findings.
Posted on May 27, 2009
I was born in September 1954 will I get heating allowance this year
1. Overview. If you were born on or before 5 August 1953 you could get between £100 and £300 to help you pay your heating bills. This is known as a 'Winter Fuel Payment'.
After that date you get winter fuel allowance when you reach state pension age.
Sep 21, 2017 | Cars & Trucks
Bonaire gas ducted heating not reaching set room temperature anymore...
has the system air filters been serviced lately
is the system circulation fab been cleaned to allow full air circulation of the system
call in a technician to check for vermin infestation preventing the system from working properly
Jun 20, 2016 | Heating & Cooling
Where do I set thermostat when temp is 10 degrees outside?
Setting a thermostat has nothing to do with outdoor temperature, but more to do with what is a comfortable setting for you and your utility bill.
A common misconception associated with thermostats is that a furnace works harder than normal to warm the space back to a comfortable temperature after the thermostat has been set back, resulting in little or no savings. This misconception has been dispelled by years of research and numerous studies. The fuel required to reheat a building to a comfortable temperature is roughly equal to the fuel saved as the building drops to the lower temperature. You save fuel between the time that the temperature stabilizes at the lower level and the next time heat is needed. So, the longer your house remains at the lower temperature, the more energy you save.
Another misconception is that the higher you raise a thermostat, the more heat the furnace will put out, or that the house will warm up faster if the thermostat is raised higher. Furnaces put out the same amount of heat no matter how high the thermostat is set; the variable is how long it must stay on to reach the set temperature.
In the winter, significant savings can be obtained by manually or automatically reducing your thermostat's temperature setting for as little as four hours per day. These savings can be attributed to a building's heat loss in the winter, which depends greatly on the difference between the inside and outside temperatures. For example, if you set the temperature back on your thermostat for an entire night, your energy savings will be substantial. By turning your thermostat back 10 to 15 degrees for 8 hours, you can save about 5 to 15 percent a year on your heating bill -- a savings of as much as 1 percent for each degree if the setback period is eight hours long.
Hope this helps..........
Nov 23, 2010 | Goodman GMS90703BXA Heater
My frig. in the garage.. The freezer works great in summer months but in winter months it doesn't. Why is that?
Good day,
That is normal. The thermostat that runs the whole machine is located in the refrigerator compartment.
When it reaches normal temperature, it shuts off. In winter months that may mean as long as 12 hours or more. Thus not enough running time per day to keep the freezer near it's normal temperature.
Engineers design domestic refrigerators to be in an area comfortable to humans. Normally 70 degrees or higher. Thus your problem.
The only solution is to bring the machine inside.
Sorry.
Thank you for using FixYa
Dec 29, 2009 | Refrigerators
I am a builder. I installed my Bosch dishwasher.
Hello Gerry, There are two (2) ways to accomplish this. The easiest is to get some RV anti-freeze (enviromentally safe version) and put that into the bottom of the dishwasher as per the instructions. Then when you return in the Spring, just run an empty rinse cycle to purge the dishwasher of the anti-freeze solution.
The other method will require you to remove (pull out from under the cabinet) the dishwasher and (with power turned off!) disconnect the sump pump boot to drain the residual water out of the unit. In some models, there is a small drain plug that you can remove to drain the water out of the bottom sump (pump) section of the dishwasher.
Good that you thought of this, as many folks forget that leaving water in their appliances in freezing conditions can cause some major headaches from burst pipes, pumps, etc. if they aren't properly winterized for the freezing temperatures they'll get in an unheated building.
Hope you find this Very Helpful and best regards!
Nov 17, 2009 | Bosch Dishwashers
Refrigerator won't work after winter shut down at camp
This is a problem we frequently run into in a situation such as yours. Refrigerators are meant to be used in continuous operation. Using them seasonally will let the high side condenser tubing, internal to most cabinets, rust through and loose the refrigerant charge.
May 03, 2008 | Kenmore 73503 Stainless Steel Bottom...
Dishwashers Logo
189 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
