Question about Hitachi 51F59 51" HDTV Projection Television
We are trying to connect the S-Video cable from laptop to tv
We connected the s-video cable to input 5 and there is no picture or sound
    Problem Solver:
  • 18 Answers
You might need to change the screen resilution on your laptop so it is compatible with tv good luck
Posted on May 17, 2009
Connecting a sony dvp-sr500h dvd player to sanyo tv. using the red, yellow, white cables that came with the sony player get me no picture, no sound. do I need additional cables? the menu on the tv screen...
Here is the quick start guide
https://docs.sony.com/release//DVPSR500H_qs_EN_FR_ES.pdf
You seem to be using the Video & Audio connection. Start at the Player. Connect cables to YELLOW Video, RED Right Audio WHITE Left Audio Then go to TV and find the YELLOW input RED input and WHITE input. On some TV's they are separate, some combine them with the COMPONENT inputs (Component is 5 cables you will use 3 of them if you only have COMPONENT inputs)
Some TV's have an input button on the remote but no on screen selection. Try pressing the input repeatedly to access the other inputs. Lastly you will not get upscaling if you are using the 3 cable hook-up. To get upscaling use an HDMI cable to connect. Be sure to not have both types of cables plugged in at the same time HDMI by itself is best. If you reply with the modelof the sanyo TV I'll try to get you more info.
Jan 05, 2018 | Cyberhome CH-DVD 300 DVD Player
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
Connect to tv
On the back of the laptop there will be a small round connector. This is s-video out. To connect the picture to your tv you just need a s-video cable. Most tv's now have s-video inputs. Just plug into the laptop and the tv , then turn the tv input to s-video (if needed) and you should be seeing your laptop display. To get sound to the tv you need to buy a few more parts to get the sound out of your headphone jack and then put it into the rca sound in jacks on the tv.
We use this setup to watch videos and such at home it works pretty good.
Jun 14, 2010 | Compaq Presario CQ50-215NR Notebook
Connection using Component video No Video
1-Locate the audio/video input jacks AND the component input jacks on the TV.
Inputs are typically located on the back of the TV, but occasionally are on the sides, top, or bottom. They may also be located behind a hidden panel or door in the television.
Look for inputs marked Audio and Video IN.
Do NOT connect the system to anything marked OUT.
2-Connect the rectangular plug of the Component Video Cable into the Digital AV Out port on the back of the Wii console.
3-Connect the Component Video Cable to the television as follows. (Note that the Red and White audio cables are bound together with a black band labeled "audio.")
4-If you do not have a TV/Video button, then the input could be labeled something different. Some common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, AV, or a channel such as 00 or 99.
http://bit.ly/2ykOBno
Oct 13, 2017 | Aspire Digital AD-1000 DVD Player
How to program the autio vidio inputs for zenith tv
Hi cathie
If you have sound it means that the tv is in aux/video mode.
Now make sure that the video output of the vcr is connected to the same aux/video input that has the sound connected to. i.e input 1 or 2 .
Also you want to try and switch with another cable to make sure that the cable you are using now is o.k.
Another way to try the tv input would be to connect something else in that input(cable box ,dvd ,video game etc,)
Try it and let me know.
Feb 02, 2010 | Televison & Video
VGA and Audio cables connected to PC but no audio through TV
if your tv has vga input there should be a "line in" input very near it. VGA can only get its audio source through a "line in" connecting to the coaxial audio inputs will apply the music stream to a different video input on your tv. your tv has video 1, video 2, vga, and so on, but the vga cannot show video and then audio from the video/audio coaxial inputs. you will need something like a dual male tipped 3.5mm audio connector.
Good luck and pls rate this post
Mar 16, 2009 | HP Pavilion dv2000t Notebook
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
Different sound to picture
When connecting VCR to TV. Verify all connections. First if the connection is with coaxial cable make sure you signal from outside is screwed to the cable input on VCR. Then the VCR/TV output has the cable running to TV input. If hooking up with RCA cables , which is the yellow, red, and white cables. Hook one side up to VCR output. Yellow for Video, while red/white to audio output matching the colors. The same is done to the Television input. yellow for video, red/white for audio. Do a test recording. Use a blank tape, not one already recorded on. Record about 5 minutes Stop recording , rewind and playback. You should see the difference.
Oct 13, 2008 | Televison & Video
Hitachi 51F59 51" HDTV Projection Television Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
