Question about Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A105 Display
Display comes on at start and work fine mometarily, then it starts to flicker and then goes black.
You can see a slight image even when its dark.
It works fine with an external monitor.
Replaced screen already, with no difference.
What should we try next?
  • jpennylynne May 09, 2009
    We just replaced the screen. The inverter was our next guess. Or maybe the video card?
  • jkpf May 11, 2010
    did you change just the screen itself or the whole top portion of the lcd including the bezel?
    Scholar:
  • 70 Answers
If you've replaced the LCD Panel already, then chances are good, the failing part may be the FLR inverter. It's a thin little chip about 3 or 4 inches in length that bridges the connection between the LCD and the motherboard. It's location varies from computer to computer though, so you may have to check with manufacturer documentation. They're not too terribly expensive to replace though, much cheaper than the LCD panel, anyways.
Posted on May 09, 2009
  • Monty Lewis
    Monty Lewis May 09, 2009
    I don't suspect it would be the GPU, if it were, I would think you'd be seeing the same symptoms on the external monitor as well.
Toshiba satellite m105 screen is almost black and flickers when function keys are pressed
Posted on Jun 16, 2009
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
My trusty laptop's monitor has begun to flicker. It's most noticeable on battery power. It hasn't progressed to anything beyond a slight but annoying flicker. Do you have any ideas?
The could be a problem with the power on the motherboard, or the inverter board for the backlight system or it could be a loose connection. Does it flicker when you're not touching it? Move the display slightly, wiggle it gentle and try pinching it on the bottom outside edges (NOT hard) and see if it flickers then. If it does that could be a loose connection.
Unfortunately you can't really tell if it's the invertor until it totally goes out.
Jun 25, 2011 | Toshiba Satellite A105-S4074 Notebook
My toshiba a105-s4034 will start to power up and the hard drive light stays on a few seconds then goes out the display does not come on.if you do not put any memory card in bay close to hard drive computer...
Your computer is trying to boot up when your memory card is installed. The memory card doesn't have an operating system therefore the computer cannot boot . You can disable all of your bios. options except for the hard drive in your bios settings which you access right after you start the computer . You'll find it by using the arrow keys and selecting boat device options in the bios settings .
May 13, 2010 | Toshiba Satellite A105-S4034 Notebook
Toshiba Satellie LCD flickering
The most common reason a Laptop display starts to flicker is because the display Backlight is going bad. Easiest thing to do is to replace the display.
Sep 18, 2009 | Toshiba Satellite A105 Notebook
Flickering Screen on Model P105 Toshiba Satellite
on the back of the LCD is a cable that goes from there to the Motherboard. Try reseating that cable on both ends. If that doesn't fix it then it has to be a problem with either the screen or the cable behind the screen.
Aug 11, 2009 | Toshiba Satellite A105 Notebook
Toshiba a105 screen goes black then stops booting up when startng
try access the safe mode.. then remove the some virus or.. if you installed same latest program remove it then start again...
it you dont installed any program check the control pannel,, add and remove program remove all programe not neccesary...
Jun 08, 2009 | Toshiba Satellite A105 Notebook
If I open my Satellite A105 display too far, it goes black.
Hi, This is definitely a loose connection problem.
Does the screen go completely black or just a part ?
If its just a part, LCD is defective. You may have to change the whole LCD screen. You can get one for ~180$ from ebay
If the whole is turning off, I guess the power cable might be little loose.
You can open the LCD panel and check if you know what you are doing.
Else take it to a normal technician and ask him to open the LCD panel and see it.
Nov 17, 2008 | Toshiba Satellite A135-S2276 Notebook
Replace monitor?
how to take the monitor off the laptop and replace
Aug 19, 2008 | Toshiba Satellite A105 Notebook
A105-s2716
The problem with the LCD screen , if the external display is working fine. The LCD needs a replacement. The same thing happened on my Dell and we had to replace the Lcd. The same can occur because the LCD cable gets damaged when you open or close the LCD
Thanks
Proton
Aug 02, 2008 | Toshiba Satellite A105 Notebook
Screen flickers
Sounds like the issue is a problem with the motherboard. Does it get worse when the cooling fan and/or cdrom are running?
Apr 27, 2008 | Toshiba Satellite A105 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
316 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
