Question about HP Pavilion dv6000z Notebook
Have HP dv6110 TX2 will not turn on no external audio
I cannot get the Laptop to turn on though there is a blue light indicating power There is also no external audio only when I plug in headset.
  • 1,602 Answers
GO INTO CONTROL PANEL, GO TO DEVICE MANAGER, CHECK THE MEDIA CENTER, SOUND, VIDEO AND GAMESS,
OR
CONTROL PANEL OPEN SOUND FOLDER, SEE IF THE DEVICE YOU HAVE IS LISTED IN THE SETTING AND IF NOT THAN YOU WILL HAVE TO GO TO CONTROL PANEL TO ADDING NEW HARDWARE AND TRY TO INSTALL AS NEW DEVICE.
IF YOU ARE IN SOUND IN THE CONTROL PANEL, GO TO THE SOUND TAB AND OPEN THE FOLDER, THAN GO TO SOUND SCHEME , OPEN THE PULL DOWN WINDOWS AND SLECT THE NO SOUND AND FOLLOW THE INSTRUCTIONS.
ROD
Posted on May 12, 2009
Why is the screen rotation is not working on hp touchsmart tx2 tablet?
what is a tx2, circa 2007 device?
its a very old laptop.
right> super old running XP, right? is it/? or Vista 32?
HP TouchSmart tx2 Notebook PC
no OS stated, what operating system is running,??????
has the OS been upgraded, or changed? we cant guess that.
The Drivers on this touch pad are failing.
if you go to HP.com you can get the correct drivers.
but they will ask you for the full model number not just terse tx2
see them here.
https://support.hp.com/us-en/products/laptops/touchsmart-notebooks
there are 4 , classes of TX2
failures like this are software or hardware caused.
if software can be virus infected, that both vista and Xp worse
will be... and endless. pain there.
or someone loaded wrong OS, or wrong drivers.
all that is called OS corrupted, in one form are another.
Id reload the OS using real HP disks.
or try the drivers seen here.
i guessed VISTA 32, if not vista 32, tell HP what it is now.
https://support.hp.com/us-en/drivers/selfservice/hp-touchsmart-tx2-1000-notebook-pc-series/3837256
Jun 22, 2017 | HP Computers & Internet
My hp tx2 tablet pc turns into safe mode and running so slow
Follow these guidelines:
1. Turn a power-off computer on or reboot a running computer.
2. Quick press the F8 key on keyboard before Windows starts, after hearing a beep sound you will be taken to Windows Advanced Options Menu instead of the normal loading page. If it doesn't work on the first try, just reboot and try again. And Select normal loading option.
Fix windows internal errors and corrupt registry to avoid such types of errors in future. I would suggest to use system utility tool Reginout.
Jan 17, 2013 | HP TouchSmart tx2-1270us Tablet PC
HP laptop screen is black
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 08, 2013 | HP VM114UA notebook
The lightning bolt on my hp touchsmart tx2 flashes
that means your laptop has no power so your battery is dead which would explain why it shut down on you, and that means its not charging so it would either be the adapter or the port on your laptop
Feb 27, 2010 | HP TouchSmart tx2z
DV8309 power up problem: blue lights on for few seconds then off
The inverter inside the lcd panel is most likely your problem. Try removing the whole lcd screen from the laptop if you are capable and run it with the external screen to confirm. leave the lcd switch off (this lcd switch above the power button turns the lcd inverter on and off)
Jun 19, 2009 | HP Computers & Internet
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
How to connect to external monitor?
You need to determine the fault first.
Can you determine exactly where the boom came from (the adapter or laptop)?
When you turn on your laptop does the LED lights indicating that there is power to the laptop and you can hear the hard drive spinning as well as the fan?
Do you know the power adapter is OK (you can test it with a multimeter)?
If the laptop is dead then the external monitor is of no use.
The laptop normally has a blue video output connector, usually on the back edge of the laptop where you can connect an external monitor or a data projector. When a monitor or projector is powered up first and then the laptop the display goes to the external video first. You can switch between the laptop screen and external video by clicking the blue Fn + F4 function keys.
Mar 01, 2009 | Compaq Computers & Internet
I have a hp paVILLION DV 9000 laptop,have been using at work station so been using external wired mouse.no all of a sudden i have no curse controll at all with external or in built mouse.cant get control...
Check the touchpad on/off button at the top of the mouse touchpad on the laptop, it's small and can easily get turned off by accident and you will think your mouse has quit working. There is usually an indicator light next to it. I'm not sure but on your laptop I believe it may be a blue light when the button is on and turns orange when switched off.
Jan 20, 2009 | HP Pavilion dv6000z Notebook
I bought a new laptop today - presario compaq, but it wont power up. Blue power light comes on, blue light where power cord goes in is blue. I have attached external screen but it does not come on even...
I had the same problem with my laptop. You might check and make sure the ram was installed correctly. One of my ram cards was not clicked in all of the way!
Jul 12, 2008 | HP Computers & Internet
HP Pavilion dv6000z Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
