Question about Whirlpool SF367 Gas Kitchen Range
Model # sf462lxsq 0 and serial# Rt3410863. The oven will not light. was under warranty and was fixed, then 3 mo. later same problem. No warranty now and he asked me to look at it. What are the common
I guy bought a whirpool range "Imperial Series" Model # sf462lxsq 0 and serial# Rt3410863. The oven will not light. was under warranty and was fixed, then 3 mo. later same problem. No warranty now and he asked me to look at it. What are the common problems in this area. I think he said he smells gas. and Igniter fires a few times. In the Parts list I'm looking at #15 or 16 may be a problem.
aborcass
  • 2651 Answers
SOURCE: Whirlpool Oven will not light Model SF385PEE Help its Turkey time
i would check the wiring tothe gas valve, sounds as if you wired incorrectly
Posted on Nov 23, 2008
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
change the oven ignitor
Posted on Dec 06, 2008
  • 10865 Answers
SOURCE: Whirlpool oven won't ignite
The good news for you is that your gas provider, the folks who bill you for the gas offer a free service whereby they will send out a technician to adjust your stove for no cost.
Posted on Apr 01, 2009
SOURCE: F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
Posted on May 29, 2009
VtToolMan
  • 704 Answers
SOURCE: Whirpool gas range - propane gas not sure oven is working right
First, the flame should be blue and without much visible yellow. You need to give the gas tube a good cleaning to get out any soot buildup and any partial obstuctions that might be causing the problem. Since you started with a yellow flame and soot, you need to get the burner tubes clean to see if you have resolved the problem after adjusting the regulator and burner valve(s).
You might need to install a different regulator to match the pressure of your gas supply source, as regulators have a specific working range of inlet (supply gas pressure) that they can operate properly at to "regulate" the supply pressure to the stove's needed pressure.
Check your manual and the installation guide to verify what the gas inlet pressure requirements are and check with your gas supplier to see what they are providing you.
To your 2nd question, yes, the gas will cycle on and off when you are using the oven, since the thermostat will call for more heat when needed and shut off the gas/flame once the temperature you set the control at, has been reached. The cycling is a result of the oven trying to maintain the desired temperature for baking.
One reason that you can smell gas when the oven is being used, is because all gas ovens have a surface vent to allow excess heat to escape from the oven compartment, however you should not be smelling raw gas (actually you're smelling the "rotten egg" additive that's put in the gas) all the time, since when the oven is turned on, a small electric ignitor is heated up VERY HOT glowing bright orange inside the oven compartment. Once it's hot enough a sensor opens the gas valve and lets gas into the burner tube to be ignited instantly by the VERY HOT ignitor. It is rare to smell raw gas with this system, but sometimes you'll get a stronger "rotten egg" smell at different times due to the gas company and their system, etc.
As to the gas smell, you should NOT be smelling gas every time the oven cycles on when baking, as a normal ongoing occurrence. During the first few uses, it is normal to smell some gas, but this should go away after a couple of uses. If it doesn't, you should look to make sure the regulator and oven controls are PROPERLY configured and set - Since you've already fiddled with these, it's probably a good idea to have someone from your gas company (or a gas appliance tech) come out and do this. Improper settings can cause some serious problems.
Hope this helps!
Posted on Jul 30, 2009
Kitchenaide oven error code control panel went blank. oven light still worked. 3 days later it went back on. it is still under warrenty what should be replaced
If it is still under warranty, let the "professionals" figure out what needs to be replaced. If you do it, you will void the warranty.
Oct 27, 2017 | Ovens
Marlin 336 serial numbers
The Model 336 series has been made since 1948.
Early rifle serial number are located on bottom tang under the lever.
Later the serial number was moed to the top tang behind the hammer.
There should be one or two LETTERS in front of the serial number, that determines the year.
If there is no letter then it was made after 1969.
May 18, 2014 | Optics
Oven will not stay heated. F1 light on.
Hello there:
on most ge models this code it can be either a (f 0) or the (f 1 ) is telling you that the the thermistor controle circuit is going bad or has failed all together. or there is a short in the erc circuit meaning the electronic controle board. ok
So i would recommend have a repairman check out the thermistor first since this is the most common thing to fail then if this passes have them test the controle board or the ecr circuit
and if the oven is still under warranty you might be able to use the warranty to get it fixed ok
Hope this is very helpful for you
Best regards MIchael
May 14, 2010 | GE JTP20 Electric Single Oven
I have a DCS Model MO-24SS. The other day I was
Main fuse is under outer cover Its a large ceramic fuse and costs about $30
Jul 25, 2009 | DCS MO-24-SS Microwave Oven
Jennaire broiler doesnt work on slidein range after using self clean oven. Its only 14 mo. old
if just your broil element does not work and the bake element does work after using a self clean cycle then your broil element must have went out , self clean is a torture proccess for any self clean oven and it runs both elements at 500 deg. F, it may be still under warranty , if not then replace the broil element for the fix.
Phil
Jun 10, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 26, 2009 | Wolf Range WKGD-2 Gas Double Oven
Whirlpool MT$155SPS-1 microwave
Cajun1112, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Cajun1112), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool MH6150XLS Microwave Oven
I have a Maytag Model MMV5207BAB over the range microwave oven that crapped out after 11 mos use. No warning, just no power. The outlet is fine I have no power surge problems in my house. This is the...
There is an internal fuse which is located underneath the side\top shell. If you have no lights or control panel, this is the most likely cause. This is not difficult to replace.
Nov 08, 2008 | Maytag Microwave Ovens
Burners Blew
if you will send me your model number off your serial plate on your range will be on front open oven door or lower drawer some where and when you bought it i need to check the service bulletins before i reply but dont rate me till were done
Jan 02, 2008 | KitchenAid KESC300 Electric Kitchen Range
Whirlpool SF367 Gas Kitchen Range Logo
180 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
