Question about Timber Creek Academy Sports Folding Aluminum Cot
Cots legs broke
Broken aluminum legs need replacement parts
Accident broke one of the plastic brackets that hold the aluminum bars on my Yamaha DTXpress III drum kit. Does anyone know how to get a replacement? Parts are not listed in the owners manual.
It is possible to order spares for most Yamaha instruments.
If you can let me know what part I can check availability for you.
Circle the broken part and email back to me.
Dan
admin@beckettsmusic.co.uk
Jan 25, 2013 | Yamaha Music
The leg clamp on my tripod is broken i need to find a replacement
They were not made to be serviced. They were made to be disposable essentially, but you might contact the folks at B&H to see if they may have a solution.
Otherwise depending how it broke, it might be able to be cemented, or reconfigured to accept a different type of clamp. I had a no name type of tripod that required some caredul filing to restore a lip on a clamp so it would lock after the original lip snapped off.
Jul 07, 2012 | Dynex 60" Universal Tripod
Buzz lightyear broke his leg
my buzz lightyear has a broken leg joint :( please help me!8f64e74e-25f3-4352-85a1-1dc0469e1a36.jpeg
Dec 27, 2009 | Thinkway Toys
On our 1996 ford taurus the return line connection broke off.
IF this Hose Nipple is A Casted Aluminum or iron and is "part of" the Thermostat Housing Simply ( Replace T-Stat Housing itself),,,, If it is Part of the INTAKE MANIFOLD Ouch!! Replace Intake manifold. I Hope this Sheds Light on your Problem so as to Lead to A Good Repair for your Vehicle, If this does help
'in any way" PLEASE don't forget to RATE me as to Your Discretion
Jan 11, 2009 | 1996 Ford Taurus
Leg lock broken
Assuming you still have the female part with the treads in tact, you can do what I did. I used a hose clamp, the kind used on radiators, but larger. First, take off the lock down knob, then put the hose clamp over the broken plastic housing and mark where the knob would screw through. Then remove the hose clamp, placing it on a sturdy surface and use a 5/16 drill bit to make a hole where the lock down know will pass through. Place the hose clamp over the plastic housing, insert the knob, tighten the hose clamp (but not so much that it restricts the tripod leg from moving) and you are done! I can send you pictures of the process and the final result. It saved me from buying a new tripod! I can be e-mailed at boingsplatplop@yahoo.com if you have questions.
-Spencer
Nov 07, 2008 | Photography
Ge 106749
I just broke a leg on my 106749 ge skillet and called customer service and was told they do not carry replacement parts for this skillet. If you would like to buy my good leg I would be more than happy to work with you! Deb
Nov 01, 2008 | GE 106749
Is it possible to buy a replacement leg for a GB1140?
I would contact the factory and see if they have replacement part available. Try their website and ask. Most large retail manufactures have parts avaiable.
http://giottos.com/
Jul 06, 2008 | Giottos GB1140 Tripod
Need replacement broken Leg
1-800-323-9519. thats the number for rival customer service they might be able to hook you up
Mar 30, 2008 | Kitchen Ranges
Timber Creek Academy Sports Folding Aluminum Cot Logo
69 people viewed this question
Top Timber Creek Rock & Ice Climbing Experts
RatanbssBD
Level 1 Expert
Makenzie Floyd
Level 1 Expert
Are you a Timber Creek Rock and Ice Climbing Expert? Answer questions, earn points and help others
