Question about GE Profile JTP56 Electric Double Oven
Re.probe and bake
The probe and bake are flashing with a sound  and baking will run for for 5 mins then it will stop.
  • Anonymous Nov 02, 2007
    My probe and bake light is flashing and beeping back and forth. I have turne dof the breaker to try and reset it, I have pushed every button. Help please its driving me nuts.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Tech told me probe jack lost ground or went bad, going to try tomorrow and let you know, the on line tech charge is 29 dollars.
maybe I ca help someone out there that can save a few bucks.probe jack is accessible from inside oven.
Posted on Dec 08, 2014
We had this same problem many times where "Probe" and "Bake" keep flashing and it keep beeping every 1 minute or so. We’ve tried all different buttons and reset through control panel. Later after searching this site we have followed the above techniques by reset ribbon in controller board but it didn't appear to work. I’ve even switch off the electricity breaker to reset the oven itself after 5 minutes. It didn’t work also, just I about to give up, I finally opened the top oven door to let all the heat come out and left it open for 30 minutes. Afterward beeping goes away. Because over return back to normal room temperature. I think this has to with temperature sensor (probe sensor) within the oven (sensor issue) because it keeps seeking probe mechanism to adjust its temperature to trigger bake. Hope this will help those who have similar problem to resolve this. We had a GE JPK44 series oven.
Posted on Dec 25, 2007
I had the same problem and pulled off the contorl panel and removed the ribbion looking thing. You might have to do this a few times and wiggle it a little. It took me about 4 trys to get it to stop. also you can lock the control panel and the beeping will stop...this was my temp fix until I figured out how to get the control panel off and what to do.
Posted on Nov 03, 2007
SOURCE:
Cant get the fan oven to heat up is this a element problem or a program problem.
Hi.
If the fan assisted cooking programs are the only one not working and the oven is otherwise heating and cooking, then problems can be:
Fan motor.
Wiring harness to fan.
The relay that activates the fan. That is usually part of control module.
If instead the fan oven is not heating at all, then check if problem is with broiling, baking, or with both. If the problem affects both broiling or baking replace the temperature probe. before replacement the probe can be tested using an Ohm meter. The probe will read about 1080 Ohms at room if good.
If problem is only with one of baking/broiling functions, then test elements or valve/ignitors, depending if oven is gas or electric.
Regards.
Ginko
Sep 18, 2011 | Electrolux Ovens
Tip
Ge profile oven probe and bake lighs flash intermittently
<P> </P> <P>unscrewed probe housing, insured  black/white wires were secured to connectors and re-installed housing.  ( white wire was not  fully seated into connector Lights no longer flash.<BR></P>,
on Aug 20, 2013 | GE Ovens
Tip
Broiling and baking element in my electric oven are not heating.
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
on Mar 03, 2010 | Whirlpool RBS275PD Electric Single Oven
When baking the oven doesn't bake evenly and always bakes quicker than the time on recipes. Items burn and the middle is raw. Can the oven be recalculated to work better?? John
Electric ovens are always different from gas ovens. You have to set the temperature on average 10-15 degrees lower and watch out 15 minutes earlier if you are baking cakes, 5 mins for cookies etc. Always bake in the centre of the oven. use a metal bowl of water in another tray which may help balance out the temperature
Jan 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I have a SMEG SE398X-5 wall oven that does not heat up. The light inside & the controls comes on but will not heat up so there is power to the controls & lights but not to the element & fan.
Hi.
If both baking and broiling element do not heath above a certain temperature, then the part to be replaced is the temperature probe, still located inside the oven cavity.
A faulty temperature probe will keep circuit to the heating elements open, affecting both broiling and baking function.
The temperature sensor can be tested removing it from the oven cavity and reading Ohms on the sensor wires. If the circuit is open at room, then the temperature probe must be replaced.
Regards.
Mar 05, 2010 | Ovens
Oven has stopped heating up
Hi.
This oven should have two elements.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
Neither the oven or broil element comes on. No error code appears, any thoughts?
Hi.
Regards.
Mar 02, 2010 | KitchenAid Ovens
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
How to set the temperature on the KitchenAid Superba oven/convect
A separate oven thermometer is absolutely necessary in baking. Something similar to this would be cheap and easy. http://www.bedbathandbeyond.com/product.asp?order_num=-1&SKU=10161738
Or you could go for a digital one with a probe.
Apr 08, 2009 | KitchenAid Architect Series KEBC107KSS...
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
1,213 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
