Question about Craftsman Garden Tractor Snowblower Mounting Kit (Craftsman)
Craftsman c459-52832
My snowblower starts, runs great , I can move forward and backward no problem. Once I put the gear on to start blowing the snow nothing happens, worked fine for 5 minutes then nothing. hopefully someone can help me out, im thinking something might of broke if it tried pushing to much snow? but im not sure. Thank you
SOURCE: engine runs will not go into gear and brake does not work
You have to disengage the transmission if automatic, There is a lever in the back pull out and up. then try to push, also make sure that the brake is off.
Posted on Mar 14, 2009
dennymulford
  • 1055 Answers
SOURCE: blowing fuse
youve got a short in the wireing ,prob right at the clutch peddle switch
Posted on Mar 18, 2009
  • 79 Answers
SOURCE: Craftsman DGS 6500 garden tractor won't engage
Hi
There is a pin in the back by the hitch - make sure it is pushed in. If it is pushed in then check to see if there are any oil leaks under it.
Posted on Apr 10, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman LT 1000 won't go into reverse or forward
the hydrostat rearend or the belts to loose
Posted on Jun 07, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
Fluid levels in gear box
Amber. With machine on level surface,fill gear box with specified gear oil until it starts running out the fill hole on front of gear box.
press the helpful button and follow me on fixya for more tips
Service
Craftsman snowblower auger gearbox lubricant
Sno Thro Engine Oil Gear Case Lube
Auger Gear Oil Sorry to ask again Snowblower Forum Snow Blower Forums
Feb 09, 2016 | Garden
Snow keeps getting stuck & doesn't shoot out, even if the snow isn't heavy, after several
View Comment - MovingSnow.com
movingsnow.com/.../craftsman-88395-30?-277-cc-two-stage-snow-blow...
Oct 14, 2015 - 28 In 277cc* Dual-Stage Snowblower w/ EZ Steer at $1049 (minus ... If you do get something stuck in the front end - yes it will slip the belt.
Cheap 2 stage Snow Blowers - There are a few good ones ...
movingsnow.com > ... > 24 in Craftsman 88172 179 cc
Nov 7, 2014 - Sears carries other brands besides Craftsman but they are all not as good of ... Briggs and Stratton 1696610 Dual-Stage Snow Thrower with 208cc ...Subscribe to our mailing list and get interesting stuff and updates to your email inbox...... up to the 28 inch 28 In 277cc* Dual-Stage Snowblower w/ EZ Steer.
Dec 29, 2015 | Craftsman 28 In 277cc* Dual-Stage...
Noma snowblower transmission is backwards, put in forward it goes backwards and so on
Dear Richard,
Your direction with the gears appears to be 180 degrees out. You may also consider flipping the entire shaft assembly. You. Knowing this assembly is put together correctly.
At this you tube link you will find information to watch for your Norma. The side bar with a catolgue has your answers.
Here is a forum and a blog that may help when the order is corrected
Small Engines Lawn Mowers etc Noma Murray Snowblower question
Craftsman Murray Snow Blower Belt and Friction Wheel Replacement
Dec 09, 2014 | Garden
Craftsman snowblower won't start
give me more information does it pull by hand or starter ?is ther some thing stuck in the drive gear ?or is it the ring gear turn it by HAnd and see if ya can go backwards with it
Feb 04, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Snowblower wont engage forward or reverse
Howdie ther is Clutch under the bottom of it that needs to be replaced take the cover off and you will see it
Jan 30, 2014 | Craftsman Snow Blower / Snowblower Bottom...
My snowblower won't go into gear when I start it.
If your snow blower is a two stage, you can tilt unit up by handles and carefully rest unit on front auger housing. (Most units you can do this, but be careful, not all do). Then, remove bolts that hold bottom plate on snow blower, and remove bottom plate. If you follow the shift linkage down from handle to where it enters inside the unit, you will soon see how it works. Most types have the gear shifter hooked up to an apparatus that moves a rubber friction disc along a shaft, further towards the center for lower gears and vice versa. My guess is that you need to lubricate the shaft that this rubber disc slides along. Try some white lithium grease and have someone carefully move shifter throughout gear range. Be careful to not get grease on round friction plate below, this is where the rubber friction disc mates up to when drive is engaged(you don't want it slipping). Try this and let me know if you have questions. If you post actual make, model and serial# I can post pics if you like. Good luck and happy wrenching!
Nov 23, 2013 | Craftsman Garden Tractor Snowblower...
Only one wheel runs in gear on my snowblower
Sounds like the key that locks the wheel to the axle shaft is missing. Look in a parts manual that came with the snowblower to see the key. Should be with the transmission break down or the wheel and/hub breakdown. If you do not have a parts manual depending on what brand and model you have, you should be able to find it on line.
Jan 19, 2013 | Garden
Craftsman 8hp snowblower starts but will not stay running.craftsman 8hp electric start dual stage modle 536881800 snow thrower
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
Dec 19, 2009 | Garden
Craftsman Garden Tractor Snowblower Mounting Kit (Craftsman) Logo
151 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
