Question about Whirlpool Dryers
Whirlpool Gas Dryer LGR4634EQ2 is not getting hot, I cleaned the vent,I don`t know whats nexts to try?
  • 1,305 Answers
You may have damaged the glow bar gas ignitor when cleaning the dryer.. it's a ceramic element that gets brittle after it has been used. And if you bang into it with a vacuum hose or tool or whatever while you're cleaning it, it can crack or break....try cycling the dryer and watch the ignitor while it attempt to heat up... if there isn't any glow at all, its the ignitor... it's a simple job to swap it out...
Let me know if that doesn't work...
KEN
Posted on May 09, 2009
Dryer gets warm but not hot enough to dry items in one cycle Whirlpool LEL8858
u need to check where your dryer vent vents to does it go up on the roof or is it through the wall right next to the dryer it might be back up with lint does it take a couple times to dry if so u might want to clean it out or have someone come and clean it like a dryer vent service good luck scott8326@hotmail.com
Feb 17, 2010 | Whirlpool Dryers
Dryer is not getting hot . The vent is clean and only warm. it is a gas whirlpool.Thanks
On cotton setting you ought to be getting 155f out the vent. maybe 160f max. You have warm air so everything must be working. That tells me the coils need replacing. they get weak and they get hot. Feel the coils after a few times and the bad coil will be very hot to the touch. the coils are sold in pairs for $20 I have a great link that shows what to do HERE
and I have another page HERE
Jan 19, 2010 | Whirlpool Dryers
I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do...
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
GEW9200L runs but won't heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting
Jun 21, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool accue temp dryer gets hot then heat shuts off
Sound like you need a new agnitor for your dryer take the model # to order part and install very carfully good luck
May 09, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Feb 01, 2009 | Whirlpool LGR3624JQ Gas Dryer
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Propane Gas Dryer (Whirlpool DUET Front Loader) not drying
Did this tech do some wash to the dryer and feel that there was no heat?
He was not a good tech
Try this first.
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 11, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool ultimate care gas dryer
the glow bar on the gas ignighter
Mar 15, 2008 | Dryers
Dryers Logo
805 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
