Question about Kenmore Dryers
Dryer quit working
Id like for someone to please tell me where the reset switch is for a kenmore 600 series electric dryer
    President:
  • 1,136 Answers
Hi, The only thing you can reset is the beaker for the dryer in you breaker panel for the house. As far as the dryer, if it doesn't start at all, you will need to test the fuse in the dryer. First thing!! Unplug the dryer. This fuse is none resetable. Most models have the fuse located in the back of the dryer. You will need to remove the rear panel and locate the fuse on the blower housing. The fuse is white and is 1/4" wide and about 2" long with two wires attached to it. If the fuse has coninuity, then it is ok. This is the most common problem. Other causes could be door switch, timer, or the motor.
Hope this gives a little help. Need more, let me know
Vic
Posted on May 09, 2009
My kenmore 600 series dryer quit, makes no noises does nothing?
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jul 01, 2014 | Kenmore 600 7962 Dryer
Kenmore 600 series electric dryer runs but wont heat
There are several things that could cause this problem but the most common can be can be checked by following this guide:
Electric Dryer Runs But Dont Heat
Jan 11, 2014 | Kenmore 600 7962 Dryer
Kenmore 600 series gas dryer not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 26, 2011 | Kenmore 600 7965 Dryer
I have a 600 series kenmore dryer and the heating element turns on when i set the timer and before i push the start button
Sorry to read about your problem, I hope this helps you out.
sounds like your start button is stuck on...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Kenmore 600 6965 Electric Dryer
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Kenmore 600 timer no longer works
This is not an easy task. you will need to disassemble the entire control panel to extract the bad or faulty timer. Extraction can be tough on some model. this will cause an inexperienced do it yourselfer to break off fragile retaining clips and screw anchors as well. you will also need to make sure that the wiring harness is re attached to the new replacement timer correctly. this is important. We recommend calling for service on all electrical repairs if you have minimal experience in this field of repair. Unfortunately , when these timers are damaged, you cannot repair them. you will need to replace the bad timer with a entirely new timer.
Jun 10, 2009 | Kenmore 600 6963 Electric Dryer
start outside at exhaust hoot look for blockage there first look for steep dip or drop in line where condensation can acumilate
May 01, 2008 | Kenmore 62602 Electric Dryer
Dryer just quit
There is no reset switch and there is no fuse inside the console.  I posted comments to your solution under the premium problem section.  I believe you could have a bad thermal fuse which is located in the rear of the dryer.  I left instructions for you to follow.  Let me know if you need further assistance.
Oct 12, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
182 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
