Question about Health & Beauty
Acs-cl scale manual - Health & Beauty
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
Service manual
HP AC adapter, HP part number 416421-021?
http://www.amazon.com/Compatible-HP-416421-021-Adapter-Charger/dp/B0050DN8X8
Plug going from AC adapter to DC Power Jack on laptop;
Center of the plug is the Positive ( + ) connection.
This is where the red Positive probe lead of the multimeter goes.
The outside cylindrical metal shell is the Negative ( - ) connection.
This is where the black Negative probe lead of the multimeter goes.
The Function knob should be set to DC Voltage.
(Unless you have a multimeter, that automatically detects whether it is AC, or DC voltage you are testing)
If more than one scale set it to the 0 - 50 Volt scale.
You should read VERY close to 19 Volts.
[Label on AC adapter.
Output: 19V / 4.74A
19 Volts at 4.74 Amp's. (Amperes)
Don't worry about the Amperage, just the Voltage ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 10, 2012 | Computers & Internet
Voltas Vertis AC not cooling
my voltas split a/c is showing CL on closing please help me out
Jul 04, 2012 | Heating & Cooling
I replaced the battery with a DL2032 instead of a CR2032 and the scale does not work. Is that the reason?
This shouldn't be a problem, as the DR and CL are referring to the manufacturer. Both batteries are 20mm in diameter and 3.2 mm in thickness. Make sure you do have the 2032, rather than the 2023 1.5v alkaline batteries.
I would recommend taking it into the store where you purchased it.
Dec 07, 2010 | Taylor & Digital Scale Lithium Scale
My scale starts out with 7.2 instead of 0.0
try removing battery if this does not work you have a faulty weight sensor
May 10, 2010 | Taylor 5757 Digital Glass Body Fat Scale
When i was fixed a problem in central ac trane i found decreased in freon r22 and the suctione line was freezed, i charged the ac with froen gas r 22 then i found that the suctione line changed and begin...
You are still low on freon. Charging AC by superheat and subcool
First charging a unit by superheat, this is only for Acs with an orifice or capillary tube.
Optimum superheat is 12° to 15° at the compressor or suction line outside the unit.
Hook up your gages and put a thermometer on suction line (large line), start the AC. Measure the temperature of the suction line and read the pressure on your gages. Theres a temperature scale on your gages for R-22 or R-410A the needle will show you the pressure on the outer scale and if you follow it down to the R-22 or R-410a inner scale that is the saturation temperature for that refrigerant, (you can also use a temperature pressure chart), now read the thermometer, let’s say the suction temperature( the thermometer) is 67° and the saturation temperature (the gages or temp. press. Chart), is 55°, subtract the saturation temperature from the suction temperature, 67°- 55° = 12° superheat.
Charging by Subcooling, this is for Acs with a thermostatic expansion valve, it’s common to see a sight glass on the liquid line (on these units with a sight glass just clear it, when, indoor room is at approximate set point of the thermostat). Optimum sub cooling is 12° to 15° at the outdoor unit.
Hook up your gages and put a thermometer on liquid line (small line), start the AC. Measure the temperature of the liquid line and read the pressure on your gages. Theres a temperature scale on your gages for R-22 or R-410A the needle will show you the pressure on the outer scale and if you follow it down to the R-22 or R-410a inner scale that is the saturation temperature for that refrigerant,(you can also use a temperature pressure chart), now read the thermometer, let’s say the liquid temperature( the thermometer) is 100° and the saturation temperature (the gages or temp. press. Chart), is 114°, subtract the liquid temperature from the saturation temperature, 114°- 100° = 14° subcool.
Oct 05, 2009 | Heating & Cooling
I lost the AC adaptor for my conair BMS10M massage cushion
yeah ! Just Go on & search for the compatible AC adapter in the market and dont forgrt to carry ur AC along with you to test the adaptor for wether it is compatible for your AC.
Or else throw your old conair AC and buy a new one !
Jan 11, 2009 | Conair Weight Watchers WW-87 Body Fat...
LOST MY USER MANUAL FOR MY LOGITECH CORDLESS KEYBOARD
Go to this page http://www.logitech.com/index.cfm/support_downloads/&cl=us,en?WT.ac=pt|3741
Find your keyboard and click on it,
scroll down and you should see Additional Information
Under that you will see User Manuals and QuickStart Guides, click on that and you should be all set with an online version of your manual. Thanks!!
Nov 06, 2008 | Computers & Internet
Digital scale
if scale  shows 0.000 after placing some weight on pan, it means sensor or load cell connection is open, please check sensor connection.
Mar 23, 2008 | Digi 2.5 lb x 0.0002 lb AC/DC Digital...
Health & Beauty Logo
46 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
