Question about JVC KD-G322 CD Player
Sub la47201remplacement - JVC KD-G322 CD Player
2 dvcoil 4ohm.subs, need 2 ohm load total for monoblok.amp. how do I wire.it
If you run one sub with the DVCs in parallel, you would get 2 ohms. If you run both subs with all DVCs in parallel, you would get 1 ohm.
If you run both subs with DVCs in parallel and subs in series, you would get 4 ohms.
If you run both subs with DVCs in series and subs in parallel, you would get 4 ohms.
If you run one sub DVCs in series and the other sub DVCs in parallel and both subs in parallel, you would get 1.6 ohms but the subs would not be balanced.
If you run both subs on only one coil and the subs in parallel, you would get 2 ohms (but only if the individual coils are rated for the full power)
Oct 15, 2015 | Ohm Car Audio & Video
Pre-out for sub in-op
first make sure the actual sub is powered on .You can tap on the RCA leading to the sub and hear the sub humming..Im assuming you do have a powered sub connected to sub out of receiver .Also you could also connect another type of speaker with RCA to make sure if it has output or not..Also make setup does have sub output ON..thanks
Dec 15, 2007 | Audio Players & Recorders
How to trouble shoot a sony sa-wm20 that stopped working
With subs, it's either
  1. a blown fuse (no power at all at the sub);
  2. a broken input (#1 cable, #2 sub input socket, #3 blown sub plate amp);
  3. incorrect connection at the receiver end or the wrong settings
You've ruled out most of this because another sub works in its place. So what's left is either sub settings, or a busted sub.
The sub settings for testing should be: Crossover frequency - Max; Volume - Mid; Phase - Normal.
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay or not.
Most subs auto sense a signal. So if the Sony isn't doing that then there's the problem. Given that these are very much a budget sub, I'd be inclined to have a look for something simple such as a broken solder joint or bulging capacitor. If it's anything more indepth then the cost to repair will outweigh the value of a replacement.
Aug 05, 2014 | Audio Players & Recorders
Sub hook up to Receiver
If the Pioneer has only one sub output connect it via a single RCA to the mono one. If it has two outputs (L&R) connect it to the L&R on the sub via a dual lead.
The other connections on the sub are for those amps without a dedicated sub output.
The manual for the sun can be seen online.
Yamaha YST SW205 Owner Manual Connections Connecting To Line Output pin...
Dec 18, 2017 | Pioneer VSX-454 Receiver
Is the sub out strictly for a powered sub or is there a way to hook up speaker wired subs to that
The sub out connection is for powered subs. To use a sub that runs off of the amp power, you'll will have to run it through the main speakers. Usually, on this type of sub, there are connectors that allow the frequencies above the sub range to bypass it and go on to the main speakers (the sub filters the lows and passes the highs on to the speakers). If your sub does not have this, then you'll have to get a separate amp for your sub to run off of the sub-out.
Dec 01, 2010 | Sony STRDH710
Can I plug just one subwoofer into my Yamaha EMX88S? What kind of sub do I need to get for it? Do I need to have 2 subs plugged in for it to sound right? Do I daisy chain the subs with the A15 speakers I...
it is not reccomended to daisy chain passive subs with main speakers, because there is no crossover unit involved. you want a sub to have a crossover frequency around 100hz, so that only frequencies lower than this go through the subs, and not in the main speakers.
you could get away with 1 sub plugged into the mono output on the front, subs dont have to be stereo. you would need a self popwered sub, or an additional amplifier+crossover for passive subs. your best bet would to be to get a powered sub and hook it up to the front panel mono out. powered subs usually already have the crossover built--in.
Nov 25, 2010 | Yamaha Emx88s Powered PA Mixer System
Subs not working.
blown sub if it sounds liek a cracking, with sub off, gently press the sub in, if you hear noise, its dead
Sep 23, 2009 | Car Audio & Video
I have 2 kicker l7's 4ohm, how do i wire them down to 2ohm?
If the subs are dual 2 ohm voice coils.....
  1. For a each sub, connect one of the "+" terminals on the sub to one of the "-" terminals. This makes each sub 4 ohms.
  2. Connect the unused "+" terminals of each sub together. Do the same with the unused "-" sub terminals. This makes the sub combination 2 ohms.
  3. Then connect the "+" and "-" sub terminals from the above step to the amp.
If the subs are dual 4 ohm voice coils, you can't connect both subs in any fashion to get a 2 ohm impedance. The best you can do is make a single sub 2 ohms by connecting both "+" terminals together and both "-" terminals together or the pair of subs 4 ohms by doing the same, then connecting one sub's "+" terminals to the other sub's "-" terminals, then connecting the other "+" and "-" terminals to the amp.
Apr 04, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do i use this?
Sharp SF2414, Сode
CH If lit steadily, paper feed section cover is open or manual feed unit not installed properly. If flashing, developer seal still installed, or toner density sensor/main board problem. EE Sub code EU: undertoned. May be toner density sensor problem or developer unit problem. Sub code EL: Over toned. May be toner density sensor problem or developer unit problem. H2 Sub code 0: Fuser thermistor. H3 Sub code 0: Fuser temperature too high. H4 Sub code 0: Fuser temperature too low. L1 Scan problem. Sub code is 0, but there is no more detail. Could be no scan drive; scan did not leave home; scan did not return home; scan overloaded; mirror motor problem; scan cable came off. L3 Scan return problem. Sub code 0. Approximately same causes as L1 L4 Sub code 1: Main drive problem. Sensor, gear, motor. L5 Sub code 2: Lens drive, motor, sensor. L8 Sub code 1 Power frequency varies by more than 5 % or for more than 5 sec. Sub code 3: AE sensor problem. PC Key counter not installed. SPFJAM Document feeder problem. U2 Sub code 1: Main board EEPROM problem. Sub code 4: Memory problem. U5 Sub code 5: high temperature at exposure glass when using document feeder
Apr 03, 2009 | Sharp Office Equipment & Supplies
5 stage band pass sub box, 1 sub stolen, box built to spec subs
I would try walling it up unless you are going to buy 2 brand new subs. the problem is the older power subs had such small magnets so they needed alot less air space inside the box. Unless you can find the EXACT subs this box was made for I would recommend chopping it and doing a single sub. if you try a replacement sub go with the 12" P1 series they are a close match for the power 12's of the past.
Mar 06, 2009 | Rockford Fosgate Car Audio & Video
JVC KD-G322 CD Player Logo
16 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
