How do i reset an oph 616 hoover washing machine
2 Suggested Answers
rebeccakidma
SOURCE: user guide manual for the
I have had this machine for 6 months now. I find it ok for a first machine. Its god for me : ie live alone, economical thinker, therefore fot wash only weekly, sometimes fortnightly and its great for that urgent "need it for later" wash.
I have got an "inkling" that your,query , is flasging the door etc because the previous cycle was either put,on hold by someone or you had a power cut.
The manual (which I lost, totally gutted bout that) says that our washer :), has a electric cut out memory board! Which u thought was brilluant on initial reading of thd instructions. ...however, when the street had a blck out, due to heVy rain.the cycle obvuously stopped but I didnot pannic as referred to manual....3hrs later. Machine started again. Went on for a while and it kept doing the same thing. Swush swush holdm swush swish hold,for at least Nother 2hrs. I was so worried. I had to turn it off. Then did a small cycle, which did as shud.
What im getting at is, I suppose u get what u pay for. Its alot of money u know but not compared to alot of machines. I think your machine is confused.
Before typing my essay I realised when u wud b readung it that you wud have had worked it out and I guess had done some more precious washin since. I reckon the trick is too treat our babies with love & attention and donr overload as it states exactly thar on nearly every cycle. (main reason im negative)....otherwise, my whites do clean white and it is quick and quite quiet
Posted on Jul 09, 2012
Display has been playing up. A message reading 'EOS' was diplayed just now. The machine has stopped working ?
Canon DLC: Article: Canon EOS Error Messages: An ...
www.learn.usa.canon.com/resources/.../eos_error_msgs.shtml
Canon Inc.Feb 6, 2012 - Canon has installed provision to display Error Codes in EOS SLRs for quite some time. Until fairly recently, the camera could basically display a single, or limited ... today's cameras do provide a wider range of possible read-outs, giving the ....Try removing the USB cable, and firing it normally to see if it now ...
problems installing digital solution disk - Canon Community
community.usa.canon.com/t5/PowerShot/problems-installing.../225
How to Understand Hoover and Candy Washing Machine ...www.espares.co.uk > Advice CentreJul 1, 2014 - Home & Office ... If a fault is detected in your washing machine, an errorcode is likely to flash up. ... how to identify error codes in a Hoover or Candy washing machine. ... code if the machine has a problem and this will either be displayed ...Now what I'm going to do is disconnect the machine and take the ...Error message E03 - Hoover Advice Centre - Hoover Serviceservice.hoover.co.uk > Advice CentreShould the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump ...Hoover Optima Washing Machine ' OPH ' Fault Codes
Dec 16, 2015 | Candy Domestic EVO14104L White 600 mm...
Hoover troubleshooting
My Hoover Spin Scrub 60 will not spray on the wash setting but will spray on the rinse setting, what is the problem?
Jan 11, 2014 | Washing Machines
Cycle stopping after filling with water on hoover oph 148
the heater may not be working or you have a broken wire
Dec 31, 2013 | Hoover Washing Machines
Hoover oph 148 stopped working through a cycle
I just had a similar problem to this with my Hoover OPH148 washing machine. The Cold Wash LED would flash 14 times repetitively after each wash cycle. The only way to open the door was to turn the controller to the off position.
I checked the heater element with a continuity test and found that the heater element had burnt out.
Hopefully this will help someone else if they see the same condition.
Jul 18, 2012 | Washing Machines
Hoover optima oph714ds error code e14
hoover optima oph 7d14 working ok but at end of wash cycle error e14 comes up what does this mean
Dec 24, 2010 | Washing Machines
User guide manual for the hoover Optima OPH 616 Washing machine
Dec 12, 2010 | Washing Machines
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
