Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Pump is not running when toilet is flushed,the sanisplit has power
kachbibi1
  • 979 Answers
SOURCE: Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Posted on Jan 28, 2009
  • 297 Answers
SOURCE: Basement up flush toilet systems
sorry Fran,that is what they run.thats just for the unit don't forget install cost too.good luck with this project.
Posted on Jul 15, 2009
SOURCE: My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Posted on Jan 24, 2010
  • 37 Answers
SOURCE: saniflo toilet top2
Sounds like you have blockage in the discharge pipe
Posted on Feb 26, 2010
heatman101
  • 43501 Answers
SOURCE: My up flush toilet makes a humming sound every 5
The pump has either gone bad or it is siezed up...you can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
heatman101
Posted on May 04, 2010
How do I fix a toilet that bubbles (small air bubbles from below) and flushes slow, and not completely very often?
Remove the toilet & have a plumbing company power snake
as much of the entire homes waste drain as possible
Maybe clogged inside the home on most runs & also out to
the street,have them do as much as they can, out to the street
Remove all toilets, so they can do good job & you can check &
clean them from under it
Have them run a camera down ALL drains & to the street
Jul 19, 2014 | Briggs Abingdon Ada Toilet Express
My Sanilflo system is fed by a toilet and a sink. When the sink fills it to operating the grinder runs for about 5 seconds and switches off. When the toilet is flushed (no solids) the grinder runs for...
The amount of time that the pump operates is determined by the amount of water that is drained into the unit. If the amount of water from the sink is less them the amount flushed then the pump will run accordingly.
Mar 06, 2011 | Saniflo SANIBEST Pump Macerator Grinder...
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Saniflo toilet top2
Jan 02, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
We just replaced out toilet because we had no flushing power on the old one. After cleaning the vent pipe and using a snake and putting on the new toilet, we still don't have any pressure when flushing...
its got a blocked down pipe lime scale will do this to you, the only way to sort it out is strip it out completly and give it a good clean, if that still failes to flush then its the flushing pump needing looking at,
Oct 25, 2009 | Cadet Manufacturing American Standard...
Grinder wont turn and toilet not flushing
Disconnect the power and pull the pump out and examine the pump. Simple and easy!
May 23, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Sanibest toilet is LOUD when flushed
Shut down the power and pull the pump from the unit and give it a exam. There might be something as simple as a item that was flushed down the toilet (pencil, pens, combs, etc.) or just a hair clump. Check that the float is free to track fully up and down. Good Luck!
May 17, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Mar 29, 2009 | Saniflo & Saniplus& Macerator Pump
Jan 28, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
57 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
