Question about Rolleiflex 4.0 FW Medium Format Camera
Shuter release button stuck
Shutter release on rollriflex stuck in ,will not come back out , where can i find discriptions or diagrams to help me fix it myself or shop in india
    An expert whose answer gotĀ voted for 100 times.
  • 206 Answers
Caused by build up of dirt inside shutter release button :drip small amount of cleaning solvent like methilated spirits , isopropanol or benzine between the button and external wall using tweezers and then lift the button up and down by inserting tweezers into the inner cable release  thread .
If this does not work you will need to remove the front cover and clean more fully the release mechanism on the inside of the fron cover. 4 retaining screws are under the leather covering in the front ( 2 on top and two on the bottom )
Posted on Oct 11, 2007
This analogue AL-1 Canon camera do not take a picture when pressing shutter release button. I guess it is because the button to the wheel located inderneath is stuck for some reason. Can I fix this myself...
From your video I can't tell whether the shutter is cocked. Can you crank the film advance lever all the way and then press the shutter release button?
Apr 03, 2013 | Cameras
Film release button on bottom of body is stuck in. Wont pop back out.
If you can not wind and release the shutter, the film release button will not come up.
If you can not trip the shutter, by replacing the mirror release magnet at the bottom will usually fix the problem.
May 22, 2010 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Nikon d60 shutter release error
press shuter release button again
Jun 22, 2009 | Nikon D40x Digital Camera
Shutter release and film and advance not working on Olympus OM-N1
for shuter ,the spring ,or mirror lock wornout,rebts in shuter may wornout,for film advance lever cheek for rewind buton on botm
Apr 15, 2009 | Photography
The shuter is jamed.
The first thing to check are the batteries make sure they are good.
Second thing to check, are you at the end of the film?, I have had lots of customers think they have a 36 exp film in the camera, only to find it is a 24 exp running out of film will stop the shutter and winding from re cocking
Third thing to check if the batteries are good is the position of the mirror, if it is stuck in the up position it may be that the shutter has just hung up, this happens when the camera gets a little olde and the grease in the shutter mech dries up and the shutter blinds get a bit stiff.
A shutter overhaul will fix this but you may be able to free up as a temporary measure. Follow the following steps.
1. Remove the film from the camera.
2. Open the back cover.
3. Hold the camera so you are applying a little pressure on the wind on lever.
4. Very gently and slowly press your thumb onto the shutter curtain material about 5-6mm, just enough to apply a little tension to the material but not enough for it to come out of its side locations.
If the shutter has just hung up this extra tension will cause the mirror to come back down and then allow you to carry on winding.
Oct 28, 2008 | Minolta X-700 35mm SLR Camera
Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
Sep 08, 2008 | Nikon D40x Digital Camera
Shutter problem
The memory card may be corrupt.  Try using another memory card.
If this doesn't work, try using the camera's reset function.
I think this is done by holding down two buttons, which should be marked with green dots. If not, check the manual.
If this doesn't work then it may be a repair job...
Aug 20, 2008 | Nikon D40x Digital Camera
Stuck shutter release button on my D100
The damage may require parts, but maybe not. If I were doing the work, I would charge in the $50-$60 range , plus parts if needed.
Nikon will likely quote you much higher $200+
You can use the repair service locater here on Fixya to find a repair shop in your area
Mar 24, 2008 | Nikon D100 Digital Camera
Lens shutter is getting stuck when camera is turned on
Mine was doing that when I sent it in to have the lens/screen problem repaired. The camera was part of a class action lawsuit and the repair was free and fast via Sony, but since then I've had issues with power. The camera won't stay on!
Dec 01, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Shutter button stuck
Some have used compressed air, blown directly into the button. this should dislodge anything that is holding the button down. Also check and see if the button is cocked in the body, you can pry it back into position and it should pop back up. It is a 2 position switch, first detent is to hold focus and bottom out is shutter release
Nov 25, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Rolleiflex 4.0 FW Medium Format Camera Logo
379 people viewed this question
Top Rollei Photography Experts
Are you a Rollei Photography Expert? Answer questions, earn points and help others
