Question about Samsung ES25 Digital Camera
BATTERIES LOSE POWER AFTER 5 OR 6 SHOTS WHY - Samsung ES25 Digital Camera
Batteries drain very quickly
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 06, 2012 | Fuji FinePix S9500 Zoom Digital Camera
Dsc60 battery drains quickly
First of all, you need to use alkaline batteries with you camera, if you use mercury ones they wont last long.
Mar 14, 2008 | Sony Cyber-Shot DSC-S60 Digital Camera
Why does my GE C1033 Digital Camera always say the battery is exhausted even though the batteries are new. And I just got it and have not left it on or used it too long.
Bet you're using alkaline batteries? You really should be using rechargeable batteries instead of alkalines, or worse yet, those so-called "super heavy duty" batteries. Modern rechargeables have over 5 times the power of alkaline batteries, and last for hundreds of shots. Today's digital cameras really eat power. Disposable batteries are good only for emergencies, and they usually only last for a few pictures as you've discovered.
Jun 20, 2011 | GE C1033 Digital Camera
This camera is using up the batteries too fast. There is something wrong here.
What type of batteries are you using?
I have only found ONE battery that is worth buying for a digital camera, any make or model. I've always had HP cameras, but my last purchase was the Canon A1100 IS. It is amazing, but all that power makes it hungry too.
I have had nothing but success with the BLUE Energizer LITHIUM batteries. They run about $5-6 for a two-pack or $10 for a 4-pack at WalMart. We get an amazing amount of shots out of these. The only time I totally drained them quickly was when I took several movies. I always date the batteries with a sharpie to see how long they last. I regularly get from 1 month to 3 months, depending on the quantity of shots.
Other batteries, even alkaline, are useless. I tried the Duracell copper tops, and got maybe 8 shots before they died! : P
So, we now only buy the blue energizers, with no regrets at all!
(And the neat part? Those blue batteries have more juice left after your camera too. Once they are not powering up the camera properly, they can be used in other things that take AA, like small flashlights, etc, and it can still power those items as well. We have a beard trimmer that I never have to buy batteries for - I just use the used camera batteries and we get even more use from them.)
Truly, I am a loyal BLUE Lithium fan for life.
Oct 30, 2010 | Canon PowerShot A1100 IS Digital Camera
I have a new refurbished kodak easyshare c160 -- the camera will not last but for one or two pictures without completely draining the batteries. i have tried about 4 new sets of photo batteries....is this...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Kodak EasyShare C160 Digital Camera
I am in Pune 411004 in India and have purchased Samsung digital es 15 camera recently. Original 2 aa Alkaline batteries have been completely used up.when I replaced these with 2 new eveready batteries...
Jun 13, 2010 | Cameras
Battery
The battery life on alkaline batteries vary according to manufacturer and power rating. Alkaline Batteries can provide up to 100 shots with typical usage. The Olympus CR-V3 long-life lithium batteries (LB-01) will provide approximately 500 shots. The Olympus Ni-MH batteries (B-01 4PE) would provide approximately 250 shots per charge and they can be recharged 300 to 500 times.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Battery life expectancy
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Batteries
The Lithium batteries that are provided with the camera will supply approximately 200 images. The Ni-MH batteries will provide approximate 100 shots per charge. The B-10LPB Lithium Polymer battery will allow 500 - 700 shots per charge and can be recharged approximately 500 times. B-12LPB Lithium Polymer Battery will deliver twice the power allowing 1000- 1400 shots per charge and can be recharged approximately 500 times. The Alkaline batteries, although can be used, is not recommended due to very low battery life.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Samsung ES25 Digital Camera Logo
20 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
