My booil safe is bs-nt 370 the key does not open
Model is bs-nt 370 I know the password the is green but key does not open I used lubricant but useless
3 Suggested Answers
loxmith
  • 21 Answers
SOURCE: Safe SENTRY S3877 can not open the door
here is the number for customer service, 800-828-1438
Posted on Jul 24, 2010
jonsnell4
  • 24449 Answers
SOURCE: I have booil safe 2 drawer I don't have factory password pls can you help us to give password to open
If you contact the manufacturer and prove ownership, they should be able to help.
Posted on Aug 05, 2016
Aug 05, 2016 | Computers & Internet
Factory password for Booil safe BS-T370
How to reset boil safe BS-T370
Jan 17, 2014 | Cell Phones
Forgot my administrator password to my Gateway M360 M460 M680
I also met this problem ever, and I try some common methods just like safe mode, net user but in vain.Afterwards I found a password recovery tool calls Windows Password Rescuer that it helps me solve my problem.The usage is simple so that PC novice can use it, you can see this article:
http://www.daossoft.com/documents/quick-start-guide-for-using-windows-password-rescuer.html
Sep 15, 2011 | Computers & Internet
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
I have a unknown password to a Administrator login to a Gateway laptop(M405) with Windows XP OS. How to unlock laptop?
The best way to do this is using the Offline NT Password & Registry editor.
You can download it at the following link:
http://home.eunet.no/pnordahl/ntpasswd/
This utility will enable you to reset the password of any user that has a valid (local) account on your Windows NT/2k/XP/Vista etc system.
The link above includes some directions on how to use this utility.
Nov 10, 2009 | Gateway 920 Series (gtwy920) Server
Replacement Key
goto SentrySafe.combox..
https://www.sentrysafe.com/customerCare/replacementKeys.aspx
request a duplicate key base on the model and serial number on the safe
Nov 17, 2008 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Mar 29, 2008 | Sentry Fireproof Safe
Computers & Internet Logo
David Payne
David Payne
