Question about Baby Lock Sewing Machines
Baby lock ellegante 3 won't thread needle
There is a small belt next to the tension that assists in threading the tension and placing the thread in the right spots. the belt is frayed and needs to be replaced. Where can I find this belt and can I replace it myself easily or does a service tech need to do it.
  • 4 Answers
SOURCE: Baby Lock Evolve wire Looper threading tool
You have to get the replacement wires from a Babylock dealer, I did too then after sticker shock at the price of that wire I learned to make a thread cradle and use that to thread difficult threads no. Take about 24 inches of regular sewing thread and fold it in half, put the open ends (together, same legnth) into the jet air port and hold onto the loop end, press the jet air threader and it will thread the machine, insert the thread you want to use into the loop you have in your hand and pull it thru the machine using the ends of the thread you put thru the machine, sounds harder than it is and works all the time. No more spending $8 on replacement wires. You can use this method for all the jet air sergers.
Posted on Dec 07, 2008
SOURCE: Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
Posted on Mar 06, 2009
  • 26 Answers
SOURCE: Tension
I answered this a couple days ago but don't know if it went through. I can sew through 6 or more layers of denim with my 226, no problems at all. In my 30 years in the upholstery business I never had a problem sewing leather, vinyl, canvas or multi-layers of fabric. The 226 Consew, the 111W and 211w Singers I had presented zero problems with heavy fabrics - and I don't consider vinyl "heavy".
You need to first of all check threading. If the machine's threaded wrong you're break thread. Also you need to oil under the bobbin case and the bobbin hook and the rest of the parts as well.
Then, loosen thread tension on top by turning the knurled knob that's on the spring that's holding the tension discs. Also loosen bottom tension on the bobbin case by turning the small, left-most screw on the outside of the bobbin case counter-clockwise. Do both with the presser foot down. Pull the thread(s) out and feel the tension. You should be able to pull the threads out with some little effort. Tighten both a little at a time until you get some tension. Run a couple seams and check where the threads meet in the fabric. They should meet in the center. Also check stitch length. If you're using 92 thread (is should be left twist), you should run the machine at about 6 - 7 stitches/inch. I'm running my machine at 5 - 5 1/2 with #69 nylon bonded, and 6 - 6 1/2 with #11 mono.
One more thing; if tension's too loose at the bobbin or top, the machine will jam in the bobbin and thread will break.
Go to www.consew.com and download a pdf owner's manual for free. You need to click on the 224. That machine, the 225 and 226 are the same.
Posted on Aug 31, 2009
  • 8 Answers
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Posted on Sep 24, 2009
yeroc
  • 397 Answers
SOURCE: Baby Lock BL3-406 tension setting messed up.
set all to 3-4
Posted on Nov 27, 2009
Needle thread does not pick up bobbin thread on my baby lock sewing machine
check needle thread tension is tight enough
you may have to check the needle / hook timing as if that is not correct , the hook will not be positioned to pick up the needle thread to make the loop
take it in to a sewing machine repair shop for a service
Feb 18, 2017 | Baby Lock Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
I have a Baby Lock Audrey. The bobbin thread is "nesting". I have tried rewinding the bobbin and rethreading the needle and bobbin thread but that hasn't helped.
Check that it is actually the bobbin thread that is nesting. Generally, bobbin thread issues appear on the top of the fabric and upper thread issues appear on the underside of the fabric.
If it is in fact the bobbin thread, the bobbin thread tension may be off or malfunctioning.
If it is the upper thread nesting under the fabric:
1. Remove the thread
2. Install a brand new needle
3. ALWAYS RAISE the presser foot. This releases the thread tension so the thread will seat properly.
4. Rethread from the beginning and check the thread path is correct.
5. Set the upper tension at the midway point.
6. Check that the bobbin thread is loaded properly
7. Retest the machine.
If it continues to create thread nests under the fabric, tighten the upper tension.
Jun 22, 2016 | Baby Lock Sewing Machines
WHY??!! *Check if thread is entangled. Check if needle is bent. So far as I can tell everything is fine, used new bobbin, new needle, still getting error. How do I know if the motor has become locked
Time to take it in and have the repair tech service & clean upper tension assembly. When you clip/ change threads be sure not to pull the thread back out of tension assembly. Snip thread at spool, raise foot to release tension and then pull the short thread out from the needle. The Automatic tension is very delicate and pulling thread out backwards can cause thread/lint build up and problems like your having. Sal the Sewing Gal
Oct 30, 2015 | Baby Lock Ellure
My top thread keeps catching and bunching up under the needle plate.
  • Raise presser foot when upper threading.
  • Thread normally through all guides
  • Lower presser foot
  • Thread needle, leaving a 6" thread tail
  • Raise foot and gently pull thread (no tension)
  • Lower foot & gently pull thread (you'll feel resistance)
  • Delint upper tension with Compressed Dry Canned Lint Remover ie: Computer Quality. Be sure no thread is in machine and foot is up so tension is released
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Jul 13, 2015 | Baby Lock Ellure
Babylock ellegante 2
Threads bits/dust has accumulated at top thread sensor or the sensor need to be replaced
Oct 30, 2013 | Baby Lock Ellure
How to guide thread on kenmore 158.13201
Most machines are very, very similar, therefore, no matter what brand you own, there's basically the same steps to follow: 1. Place good quality thread on spool pin, back right-hand side of machine and raise presser foot UP. 2.Pull thread taut from spool.Make sure silver take-up lever raised to highest position. 3. Guide thread under first tension disc. 4. Hold thread taut, guiding thread into next tension disc. When you get to the take-up leaver (silver lever on right side of machine that has a hole at the top--hold thread taut guiding it from right to left through hole, bring thread down left side of it, and put thread into tension bracket, hold thread taut! Put thread in back of needle into another small bracket and pull thread towards you. Time to thread needle: put thread front to back into eye of needle. Put thread under presser foot and pull under the center of it a good 6".Lower presser foot on scrap of fabric to test. Turn hand wheel toward you to lower needle into fabric scrap. Use foot (or knee depending on machine) to start machine. Do not pull or push fabric but gently guide it. Jimmy Place fabric scrap under needle. Low
Apr 04, 2012 | Kenmore Sewing Machines
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Aug 11, 2008 | Sewing Machines
Does not stitch lower thread
Make sure when you thread the machine you have the thread seated into the tension assembly on top, then make sure you have the threading ports locked and the switch in the proper place for each looper threading, the machine will only partially thread if you do not have the port locked and it will even still sew although not properly.
May 25, 2008 | Baby Lock Imagine
Sewing Machines Logo
29 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
