Question about Frigidaire FRS23R4A Side by Side Refrigerator
Need to remove door handles in order to get it through the door.
I am moving the frig to the garage. I cannot get it through the door. I need to remove the door handles to get it through the door but cannot see any way to remove the handles. Frigidaire FRS26ZNH Side by Side.
You have to remove the screws under the magnetic door seal . The inner side of the door seal will
lift up enough so that you can get to the screws.the screws hold the door seal and the inner plastic liner in place.When you have removed enough screws, you will be able to pull the liner out so you can get to the screws holding the door handle on.
Posted on May 09, 2009
I have a craftsman 3/4 hp 315 mhz garage door opener model 13953990ds when ativating it to open it only moves 6 to 8" forward and back and stop. i have tried all steps in the manual can get it solved
If you've readjusted the opener, and it still isn't working, you need to have a trained door technician come out and adjust the tension on your springs. To determine this, pull the red release handle to disengage the opener from the door, and try to lift your door by hand. You should be able to move the door easily, and it should stay at the half open point without falling or rising. If the door is hard to move, excessively heavy to lift off the ground, or will not stay open, the door itself is the culprit. If the door is fine, the opener will need to be serviced.
Sep 02, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
Is it possible to replace the handles on the KitchenAid 42" built-in stainless french door refrigerator (KBFC42FTS) with different handles? Ideally handles that look more like the handles on the Pro...
most the handles will inter change . you will need the model # of the other frig in order to get the ones you like . but keep in mind they are not inexpensive . I looked up one of these pt # 2316868 stainless handle and are sittind down! they are $ 101.93 each . . and you need 3 .. hope this helps mm feed back pls
Jan 20, 2011 | KitchenAid Architect ® Series II KBFC42FTS...
I need to know how to remove and replace the door handles on my Kenmore side by side Frig model number 106.9555752. Would prefer a site to download or read the manual on how to do this.
Hi!!
To remove the door handles on your unit, all you need to do is remove the handle end caps using a small screwdriver or similar object and the two 5/16" hex-head screws. same for both doors. Click on the following link for door diagram. http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/10042576-00006.png
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 12, 2010 | Refrigerators
How to remove a door panel in a 2001 buick
On the inside trim, you can remove screws (these screws may be covered by filler pieces or may be visible, or they may require you pry a plastic piece off that covers the screws) that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls.
Jun 21, 2010 | 2001 Buick LeSabre
Need to move frig. Handles must come off. How do the handles come off?
your best bet is going to be to take the doors off its usually very easy 3 screws on top and 2 on bottom of each of them sometimes u can take the handles off there will be a lil square u can take off and ull see a screw behind it there should be 2 on each handle however some companies put their screws behind the inside panel making it nearly impossible to remove just the handles
Mar 01, 2010 | Samsung RF265AA Bottom Freezer French Door...
How to replace driver side mirror on a 2005 ford focus.
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Jun 07, 2009 | 2005 Ford Focus
Craftsman Garage Door Opener - Gears need to be fixed
Unplug the unit and remove the cover, usually eight screws, if you see a lot of white dust in the cover check the nylon drive/worm gear, they will need to be replaced.
Apr 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sideview mirror
Oct 23, 2008 | 1994 Buick Century
Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
Jun 22, 2008 | Refrigerators
Frigidaire FRS23R4A Side by Side Refrigerator Logo
714 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
