Question about Health & Beauty
Turns off when i close it - Health & Beauty
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
How to turn off cargo area light hyundai i30 2013 hatch
Usually, it turns off automatically after you close de lid , it´s a switch that works with the open/close movement of the lid. Sometimes it can be clogged with some dirt and not work properly, check first if it turns off after closing de lid all the way, also check when the vehicle is closed by the key if it´s still on.
Oct 24, 2015 | Hyundai Cars & Trucks
Sun roof wont close
theres a way to close it by taking off the panel above that covers the motor and putting a allen wrench into the middle of the motor unit and turning it i think clockwise. If the gears are stripped it wont work...but if its just the motor then manually turning the gear should close it. I figured out which way it needed to be turned to close then put a allen attachment on my cordless drill and made it easier cause it will take awhile
Dec 12, 2013 | 1997 BMW 328
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
How to turn off the closed caption on the tv
Check the tv remote for a button that said CC.Used this CC button turn all CC1.2.3 ...to off.These will stop all the tv close captioning functions.Or check the tv Menu goto Close Captioning 1,2,3..close all to off,turn off all the text 1,2,3...to all off too.
Dec 01, 2010 | AOC Televison & Video
Trunk is broken.
With the trunk open try putting the key in and turning so that the latch swings open. This may be the problem. The latch may be stuck closed. with the key turned make sure the latch is open if it is not then take a scrwedriver and pry on the latch with the key turned to open it. Then try to close the trunk. I hope this helps. Don't forget to rate my answer. thanks.
Feb 21, 2009 | 1999 Mitsubishi Mirage
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on. can' turn off closed captioning 20" ws
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Jan 30, 2009 | Televison & Video
Spanish closed captioning stuck on Tobisha 46RV530U
Did you change the language to English? turn off closed cap.?
Jun 01, 2008 | Televison & Video
Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Dec 08, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Health & Beauty Logo
101 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
