Question about Sanyo Heating & Cooling
Rcs-sh1bg faulty no heat is being generated by the machine and the yellow ligt flashes on the receiver.Fan is still blowing.
3 Suggested Answers
The HVAC Guy
  • 30 Answers
SOURCE: gas pak intertherm - heat
it is not the thermostat. the fan you hear is likely the vent fan which will run continuosly if there is a problem with ignition. this is to give you an audible signal that something is wrong
Posted on Oct 30, 2008
shastalaker7
  • 1515 Answers
SOURCE: intertherm mmha070
Hi, did he bypass the high limit to see if it was bad? Sounds like you are getting false codes and you have a problem in your module or main board, which ever you have. The way it is acting, saying the high limit is open but the tech says its not, I would change the board.
Shastalaker7
Posted on Dec 02, 2011
Unit not generating heat -
More in likely heating element has failed and needs to be replaced...
Mar 04, 2015 | Heating & Cooling
I changed battery and pressed ACL but remote is not working
check the infrared led on the remote by holding the lens of a camera phone to it like taking a picture. press any key on the remote. if the remote is fine you should see the led flash when pressing the keys , if not then the remote would probably be faulty.
if you see the led flash then it would more than likely be the evaporator remote pickup that is faulty and needs to be replaced
Nov 01, 2013 | Sanyo RCS-4MHVPIS4U Wireless Remote...
Intertherm mmha070
Shastalaker7
Nov 14, 2011 | Intertherm P3RA-048K Air Conditioner
I have a Carrier Infinity 96 gas furnace with no heat
That means that the furnace is throwing a code to trouble shoot whats wrong. Most of the time, furnaces will have a code list on the inside of the door cover to explain what each code means, some of them don't. Its hard to say what it could be without knowing where to start. However, answering a few questions with someone knowledgeable over the phone if possible could help speed things up, but it would involve you being at the furnace and seeing what happens before it throws the code. If you do have a code list, this would help tremendously.
Feb 03, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Sony vaio has stopped booting up screen remains black
do it only if u r a professional..
assuming that the system bios has not been flashed or updated in a wrong way..if so, u gotta replace the m/b, itz a permanent failure..(though there r some exceptions)..
well to b on safe hand..do the following:..
1) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
2) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..
3) check for ac main supply, battery [in case of laptop] and fuse..
4) open the chassis or cabinet, clear dust neatly..
5) check all the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try repairing or replacing the power supply with a standby n see..[skip this step in case of laptop]..
6) check for the cpu fan is rotating and the cpu generating heat..try replacing the cpu with a standby (if no heat is generated)..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8) there may b a chance for m/b's crystal clock generator to b faulty..try repairing or replacing the m/b with a standby..
9) there may b also problem with ur monitor or dispaly unit, try replacing with a standby..[check the ccfl/inverter circuit/lcd in case of lcd(s) or laptop]..
10) try replacing/installing a substitute Display Adapter/Card..[or fit to VGA Out port, in case of laptop]..
seek professional assistance of ur system admin/vendor....
Nov 07, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
No display on monithor cpu fun runs &but mobo led
assuming that the system bios hs not been flashed or updated in a wrong way..if so u gotta replace the m/b..
1st see if the ram(s) is loose/faulty..open n resit it..
check for ac main supply and fuse..next check all the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try repairing or replacing the power supply with a standby n see..
if all above are ok..check the cmos/system battery..(above +3v)..
check the cpu fan rotating and the cpu generating heat..try replacing the cpu with a standby (if no heat is generated)..
there may b also problem with ur monitor or display adapter, try replacing with a standby..
hope it'll b enough to solve ur problem..
Nov 03, 2009 | Intel D845GVSR Motherboard
My Presario F500 doesnt power on.. whats could be the problem.. I can see the green power led on.
Oct 31, 2009 | HP Compaq Presario F500 F700 and G6000...
My system donot boot at all
1st check for ac main supply and fuse..next check all the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try repairing or replacing the power supply with a standby n see..
Oct 30, 2009 | Computers & Internet
No power in my board
Oct 29, 2009 | Intel Motherboard
Heater not working when on Heat but working when on Fan
is there a venting fan, that may be faulty not sending power to heat
Aug 03, 2009 | Heating & Cooling
Heating & Cooling Logo
91 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
