Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
My tecumseh 5 hp engine will start but then after
This isn't about a tiller but a small engine on a dredge but it is a tecumshe engine.   My tecumseh 5 hp engine will start but then after running for about 5 minutes quits and won't start again until it cool down.  tecumseh 5 hp HS50-67124C SFR 1131B
  • 246 Answers
Hello:
Operate the Engine Unitl it Quits and then Check for Fire to the Plug.
If No Fire, then the Ign Coil/Module Requires Replacing.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
How do I adjust the carburetor on an Ariens 5020 tiller, model #901016, with a 5 HP Tecumseh engine?
close the needle valve completely, then back it off 1.5 turns. Adjust from there for most efficient fuel usage.
May 04, 2015 | Ariens Rear Tine Tiller 17 901028
How to change oil in 6.5 Tecumseh
You need to open its small tank and fill up the fuel.
Aug 23, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh small engine troubleshooting
Check point gap---gap to magneto/ fly wheel ---condenser--HT lead. switch wire is not shorted out.
Apr 22, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
If I tilt engine side to side or front to back it smokes excessivly. Otherwise runs good no smoke
is the oil level overfull ?blueish smoke or the float level off and it's flooding black smoke blackish smoke
Apr 28, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
No spark on my murry riding lawn mower it has a tecumseh ohv135 replaced the spark plug
clean the flywheel, and the contact area on the coil. if this doesn't fix it then you need a new coil.
Nov 03, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh 17.5 hp ohv engine won't start
check valve clearance. if ok you going have change carb.sometimes i rebuild a carb everthing seam ok but carb wont work right so i have get a new carb and it works fine evertime
Jul 20, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
My 6.5hp only starts for 5 to 10 seconds whats rong with it
check for fouled spark plug and or bad fuel in the carb float bowl.
Jul 06, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Despite changing the sparkplug and proper choking, etc. no start
The most likely culprit is a clogged carb - a very common problem indeed on Tecumseh motors. Pull the carb off, open it up, spray everything with cheap carb cleaner (especially the bottom "bolt" that hold the float cover making sure it sprays out of at least two sides as that "bolt" is also the jet), make sure everthing lines back up as you pulled it apart and now try to start it up again! Bet it works, I see it all the time on small engines left with small amounts of gas in the system. Good luck, and I hope that gets ya runnin!
Mar 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
1,187 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
