Question about LG LHD459EL Dehumidifier
Power button does not work
After turning the unit off in order to empty the bucket, the power button stopped working and the unit can't be turned on.
heatman101
  • 43501 Answers
SOURCE: Dehumidifier shuts off with a bucket full error
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on Sep 16, 2010
SOURCE: The bucket full light flashes even though its
I have the exact same problem. I suspect this is the same as the "CH 01" problem others had with a different unit that seemed to be the bucket switch. I still need to confirm.
Posted on Dec 15, 2010
heatman101
  • 43501 Answers
SOURCE: My LG Dehumidifier model LHD45EL stopped working.
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Posted on Jan 27, 2011
heatman101
  • 43501 Answers
SOURCE: Have n lhd659ebl dehumidifier. Worked for 10
heatman101
Posted on May 27, 2011
heatman101
  • 43501 Answers
SOURCE: I cannot get the unit to run, I get a "CH"
heatman101
Electrolux EXD15DN3W dehumidifier has power to unit, but wont start operation? Display is off, on button doesnt respond, but LEDs light and beeps when bucket is removed. Any advice much appreciated.
The bucket interlock may be defective. It works correctly to signal when the bucket is removed but doesn't signal the power switch that the bucket is in place.
Nov 23, 2016 | Dehumidifiers
When I press the power on button, why does it just beep and won't turn on?
There is an interlock that shuts down the dehumidifier when the bucket is not in place or not seated correctly. There also may be a "bucket full" sensor that shuts it down mistakenly. Another possibility is that the compressor has failed.
Dec 18, 2015 | Dehumidifiers
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
Says bucket full and it is empty
There is a float switch somewhere to measure the level of water in the bucket. That switch is out of position or broken. This can happen if you are not careful removing and re-installing the bucket. Look at the area around the bucket and you should be able to find and fix the switch. Make sure the power is off when you are doing this.
Nov 13, 2013 | LG LD450EAL 45 Pint Dehumidifier
Model 53701 purchased 2003. Hardly used. Has been on working fine. Shut it off to empty, pressed power to turn back on, & Nothing. Dead. It is not the plug Help barb
Barb, if thee water collection bucket is not properly installed or the float valve in the top of the bucket is stuck in the UP position, the unit will not turn back ON.
Remove the bucket, check the float valve's position (if it's stuck in the UP position, jiggle the arm of the float valve to make ir return to the DOWN position). When reinstalling the bucket, be sure it fits "squarely" from top to bottom into the holder, so the it will make contact with bucket safety removal switch. It should not tilt down at the bottom at all.
Hope this helped you and thanks for choosing FixYa.
Aug 04, 2011 | Kenmore 53701 Dehumidifier
Hello, I have a Whirlpool dehumidifier Model# AD25USV (recall adjustment already complete) I have never had any technical problems or damages to the unit, and it has worked great, until...
Hello Shane
Mine won't beep at all. But try this trick I watched the guy do when he came to service mine for the recall they had and push Humid button fan button and power button first hold the first two then push the power button and hold all three for awhile. What this did for him was verify all systems working all the lights came one in sequence.
I do this to mine and will beep twice and nothing else. I've taken mine apart to check the fuse and it's still good so there must be a component that is not working.
On the back of your unit you will find a 800 number which will get you in touch with Trans Global Service which serviced it for the recall.
George
Jul 07, 2011 | Whirlpool Dehumidifiers
Just stopped working. When I turn unit on the power light comes on for about 2 seconds then goes off, nothing else happens. Any ideas?
It may simply be that the water collection bucket is not installed properly or the air intake filter is clogged.
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Remove the air intake filter and clean it, if necessary. While the unit is unplugged and OFF, remove the water collection bucket and reinstall it. Making sure that the bucket fits "squarely" from top to bottom, in the bucket holder. It must make contact with the bucket safety removal switch, to activate the unit. Once you have reinstalled the bucket, make sure the bottom of the bucket is not tilting downward.
If you cleaned the filter, be sure it is totally dry, before reinstalling it. Then plug the unit back in, turn the Master ON/OFF Switch to ON and if everything was done correctly, the unit should start and run. DO NOT OPERATE THE UNIT, WITHOUT THE AIR INTAKE FILTER INSTALLED.
Hope this helped you to troubleshoot and solve the problem.
Jun 18, 2011 | Maytag Dehumidifiers
Has been running fine. my daughter emptied it yesterday morning and didn't put the catch container back in the machine properly and a red light (small round) on top left of machine was on when I went...
Actually, the fan shouldn't be working if the water bucket is not installed properly. So, I believe it's more of a case of the electronic controls need to be reset.
To accomplish this, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes.
After the time as elapsed, plug the unit in and turn the Master ON/OFF Switch to ON. The Bucket Full light should not, now be ON. And the unit can function as it should, after you reset the controls for maximum humidity extraction (32 - 35%).
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Danby DDR586R Dehumidifier
Dehumidifier is saying bucket is full but it is empty
Here is a tip that I wrote to help people with just that dehumidifier problem..
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Mar 30, 2010 | LG LHD65EBL Dehumidifier
LG LHD459EL Dehumidifier Logo
51 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
