Question about Probasics Rite-Neb Mini Compressor Nebulizer
There is no mist coming out of the mouthpiece of my nebulizer, but there is air going into the medicine cup
No medicine coming out of nebulizer
Replacement of neb kit the most common cause. Try this first. Then get back with me.
May 31, 2010 | Respironics HS800 Disposable Nebulizer Kit...
Vapour does not come out of Omron NEC28 nebulizer
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Apr 19, 2009 | Health & Beauty
Omron nebulizer will not mist. All tubing is intact. What to do?
Mar 23, 2009 | Omron Healthcare Omron NE-C25 COMP-Air...
Very little mist coming out
Jan 25, 2009 | Mabis CompMist Compressor Nebulizer
Probasics Rite-Neb Mini Compressor Nebulizer Logo
64 people viewed this question
Top Probasics Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Probasics Health and Beauty Expert? Answer questions, earn points and help others
