Question about HP Compaq Presario SR1720NX (EL435AA) PC Desktop
Disk download free recovery
Recovery disk
No hard drive detected!
Hi Didier,
You can try a free data recovery program: Free Download Data Recovery Wizard EaseUS
Note: In case the hard drive hardware is broken , so you will need professional data recovery service: The World Best Data Recovery Services by datarecovery com
G'Luck !
Mar 30, 2014 | Dell Latitude E6500 Laptop
I want a free registration key for card recovery v 6.10 build 1210
Let try Cardrecovery 6.10 Build 1210 + Lifetime Crack Registration Key By Keyguru.blogspot.com
http://keyguru.blogspot.com/2013/06/Download-Cardrecovery-610build1210-with-key.html
Jan 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8 Home Edition http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8030 Professional Edition set up disks for floppy http://www.download3000.com/download_17676.html XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
NOT ABLE TO INSTALL WINDOW XP
Hi meetabdullah,
Have a nice day.
If you're running Windows XP and your computer software crashes or becomes unusable, you may have to run Windows XP recovery to reestablish your software and make your computer usable once again. When purchased, many computers don't come with a Windows XP recovery disk, but you can download one for free. The Windows XP recovery disk holds almost all of the computer software and files that came loaded with your PC and can assist you in rebuilding your hard drive.
Here are some instructions that somehow could help you:
1.Place a formatted disk in your disk drive. Click on the "Download a Windows XP recovery disk from Microsoft" link in Resources below. Click "Download." Then click "Save." Find your disk drive on the menu and click "OK."
2. Remove the disk when the Windows XP recovery disk download is complete, and place it in the computer on which you need to use it.
3.Shut down your computer; then turn your computer back on. Your computer will automatically start up running on the Windows XP recovery disk, which will allow you to install Windows XP once again.
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=18804
Hope this will help you.
Thank you for using fixya.
Dingraloids.
Sep 24, 2011 | Dell Computers & Internet
MY BUFFALO EXTERNAL HARD DISK HD PXTU2 IS SHOWING 297 GB UNALLOCATED. I THINK ITS PARTITION IS CORUPPTED
Hi guy,
You can try a partition recovery software to recover your corruptted partition.I have succeed to recover deleted partition with Tenorshare data recovery.It can recover deleted,formatted,corruptted partition after deeply scanning your hard drive to look for lost data.
Anyway,you can download a trial version and scan your hard drive for free to check out whether your partition can be recovered. http://www.any-data-recovery.com/index.htm
Jun 18, 2011 | Computers & Internet
Steps on how to make a recovery disk
first i recommend you format your pc first..
after that install all the application that are important...
don't install games i suggest...
then..
after that..
install a recovery disk application..
there are many free applications that you can download in the net..
click here
this is one of them..
after you have installed it make your recovery disk.. just follow instructions and you will surely have one...
this is another one free recovery disk software...
click here
Feb 08, 2010 | Gateway E-6000 Deluxe PC Desktop
I need to factory default set my Acer Travelmate 2490. I do not have any recovery disks.
For Recovery Disk here's the link:
http://www.user-guides.co.uk/cddownload/Acer/AcerTravelmate/Acer-Travelmate-2490-XP-Driver-Recovery-CD-Restore-Disk-1093.html
The fact is according to this website, it's not free.
Jan 11, 2010 | Computers & Internet
Need a recovery disk for acer travelmate 290
do u have another laptop or pc.
if u have open google then open isohunt then.
1st download nero iso maker
2nd download recovery disk for ur laptop
then u nid a 4.7 gig blank disk then burn the recovery disk
Dec 12, 2009 | Acer TravelMate 290 Notebook
I need a recovery disk for Sony Vaio VGN-NR11s/s . The notebook was formatted and i didn't created recovery disks and it needs recovery disks to intall the programs to the unit
Contact Sony with the purchase date/info & seriel #. They will either replace the disks free or for a nominal charge in most cases. They are the only source to get the recovery disks for your system as purchased. Sorry.
Jul 08, 2009 | Sony VAIO Notebook
Toshiba recovery disk #2 A100
Due to copyright law there will be no available exact disk content to download. If you just need the drivers and utilities that came with the CD, you can download from http://support.toshiba.com. If you need to perform full system recovery you can order the CD from Toshiba.
Toshiba Hotline 1-800-457-7777
Good Luck
Jan 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Open Questions:
HP Compaq Presario SR1720NX (EL435AA) PC Desktop Logo
21 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
