Question about Dimplex Home
My fire just stopped working. When I turn it on a small red light flickers on the inside on the right hand side. It's nothing to do with the bulbs at the bottom as I've tested these and they are fine
MicrowaveSvc
  • 9085 Answers
SOURCE: Kenmore Microwave Model 721.67601790 lights don't work!
This seems to be happening to this model a lot!
We see (and repair) this a lot. The problem is on the control panel, whichwe regularly repair nationwide by mail for $39.95 postpaid in about a week.
Atour site, we have a video available showing how to remove a typicalover the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filamentshorts, or when the bulbs are removed or installed without firstunplugging the oven from the power line. Either can cause such afailure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 21, 2008
SOURCE: one red light bottom right hand corner
Posted on May 07, 2009
SOURCE: Audi A4 2002 Low beams & Right front turn signal stopped working
but on 2002 A4, F20 and F21 are empty! Does anyone has an idea where the headlight fuses located?
Posted on Jun 10, 2010
  • 119 Answers
SOURCE: My tv wont turn on when i press the button, the
The capacitors in the power supply are bad. Take the back off, look at the capacitors, "barrels", if the top is bulging up, they are bad. Caps are around $2 each at radio shack x 6?
Posted on Feb 25, 2011
canwoodjc
  • 3301 Answers
SOURCE: Left hand turn signal is blinking too fast.
normally when that happens its one of two things,, one of the bulbs has gone bad and the filament has arched over the other filament , so check the bulbs with a tester not just by eye , and if thats all ok, check the flasher unit itself, which I doubt in this case since its just one side is the problem clean the base of each bulb so you know they h ave a good ground
Posted on Jul 03, 2011
What kind of a light bulb is needed for the febo flame electric fireplace?
Flickering flame fires generally use a fairly ordinary tungsten filament incandescent bulb, except the Fireglow bulbs are coated with an amber coloured lacquer. The heat from the bulb causes an upward current of air causing a small "windmill" to turn and cause the light to flicker.
That is the traditional method but ultra modern fires might use a higher-tech solution.
Oct 22, 2016 | Heating & Cooling
Tip
BMW 650 Tail Light Problem
If you find that your BMW 650 CS/GS/Dakar tail light doesn’t work at all or flickers when riding, chances are the metal power terminals inside the bulb socket are no longer making a good connection with the metal bumps on the tail light bulb. This is a very common problem with the BMW 650 of all makes, models, and years. Fortunately, there is a very easy fix.
Due to excessive vibration, temperature changes, and replacing light bulbs, the two metal power terminal tabs inside the tail light socket deform and get pushed too far back inside the tail light chassis. This prevents the tail light bulb from making good contact with the power terminals and the smallest vibrations can cause the electric connection to break temporarily or indefinitely.
To fix the problem, all you need to do is pry the two metal power tabs forward just a little so that they make a better connection with the metal bumps on the tail light bulb. If you look at the back of the bike, the red tail light casing on the 650 CS/GS/Dakar is held in place with two screws. If you remove these screws the red tail light casing comes off and you have access to the light bulb inside. At this point, turn the ignition on, but you don’t need to start the bike. Remove the light bulb by pushing in and twisting clockwise about 1/8 turn. If the bulb flickered while removing it, then the bent power terminals are most likely the cause.
Looking at the tail light bulb you should see two metal bumps. These bumps need to make a good connection with the two metal power terminals inside the tail light casing. Turn the ignition off and find a small tool that you can use to pry the power terminals forward just a bit. Make sure the bike is off and you don’t want the power terminals tabs inside the tail light casing to touch.
After you have made the adjustment, turn the ignition back to “on” and re-insert the taillight bulb. If the bulb is lit, then you are done. If it still flickers a bit and doesn’t stay lit, then you will need to continue prying the tabs forward until a good connection is made.
on Dec 18, 2009 | BMW 650 Cars & Trucks
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
The light on a fan is flickering. It doesn't appear to be the light bulbs. This fan has a remote control and it controls the fan OK and turns the light on and off but it flickers. What could be...
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Sep 22, 2011 | Vacuums
Lights flicker on ceiling fan: We have 4 cfl bulbs in a ceiling fan light fixture that have recently started to flicker. They've been there for a while without the problem, so it's not a matter of a new...
It is not a ceiling fan or wiring problem. It is your bulbs. Normal CFL bulbs do not work in dimmers or with remotes. Remotes work on RF signals and cause interference with the bulbs. You may also notice a buzzing sound and the lights may not go out when you turn off the switch. It is a fire hazard, can invalidate your warranty on the bulbs and will shorten their life. Try changing the bulbs to the new dimmable CFL's and see if it helps. It should eliminate your problem altogether.
Mar 15, 2010 | Hampton Bay 52 In. White Redington...
I have a Flamerite fire, model is called Isis. The fire come with a remote control which you use to turn on the lights and the heat. The fire is not working, when you press the remote the bulbs on the fire...
Hi I have the same fire with almost the same problem, I even bought some new batteries for the remote thinking that may be the problem.
I bought my fire suite second hand ,(Vega suite with Isis inset) in almost new condition and absulutely love it, so am gutted it has stopped working , Someone said , ''It could be the hidden bulbs at the backof the isis inset that need changing, But on trying to find access to the bulbs I just cannot find a way to get to them, There is 4 screws on the near inside which previous owner has cross threaded and wondered if that is the only way to get to them, If you have any ideas I would really appreciate your help and will contact you also if I can find a solution, Take care have fun
Maureena
Dec 14, 2009 | Dryers
Freezer stopped working
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary
Mar 22, 2009 | Kenmore 57029 Side by Side Refrigerator
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Home Logo
19 people viewed this question
Top Dimplex Home Experts
Donni Steen
Tom Chichester
Are you a Dimplex Home Expert? Answer questions, earn points and help others
