Question about RCA RCU300WBL Remote Control
What is the code for samsung tv using the systemlink 3 rca remote
    President:
  • 272 Answers
Unfortunately there are a lot. I can narrow it down for you. From the manual the codes for samsung tv's are: 006, 011,014,015,019,027,036,037 and 077. For a complete list of codes for your remote go here:
http://www.thompsontv.com/rcarc.html
Posted on May 09, 2009
Samsung tv pch521r , samsung remoteAA59-10083y will not operate samsung vcr/dvd2000 need two digit code
Posted on May 21, 2009
  • drew098 May 21, 2009
    hrew C Harris
    109 Mouldy RD Suite 11-B
    Lawnside NJ
    856-672-0163
    Objective: An Test Tech for PLC and Surface Mount
    Experience:
    Inductotherm Rancocas NJ
    PLC and Production Test 10-2008 to 3-2009
    Inspect and Test all solid state devices in a environmentally controlled Test lab,
    Tested fiber optic Analogue to Digital converters and D to A converters, optical amplifiers,
    optical transmitters and receivers optical regenerators series-core fusion splicers
    Performed extensive test on Programmable Logic Controllers VIP boards IDAI boards, MIC boards with
    built-in computer with advanced diagnostics performed test on a wide variety of control
    modules, such as Firing Control Digital Control and Mechanical Control Modules
    Component level trouble shooting repair and replace surface mount.
    Radwell Inc Mount Holly NJ
    PLC and Surface Mount Tech 10-2005 to 1-2007
    Read work procedures, followed production drawings and sample assemblies and received verbal instructions.
    Assembled electronic components subassembly products for Surface Mount technologies resistors, integrated circuits and sockets, on print circuit board
    Routed and connected wires between individual component leads and other components, connectors, terminals and contact points. Stereo microscope used for BGA integrated circuits
    Installed finished assemblies and subassembly in surface mount controller.
    Test Technologies Mount Laurel NJ
    Bench Tech 11-1999 to 11-2004
    Tested electronic components and circuits to locate defects, using oscilloscopes, signal generators, ammeters and voltmeters.
    Disassembled equipment and replaced defective parts, using hand tools and power tools. Mechanical parts, such as control lever mechanisms and water impellers.
    Soldered loose connections and replaced defective parts, such as tubes, transformers, resistors, condensers and switches, using hand tools and soldering iron.
    Replaced defective components and wiring and adjusted mechanical parts, using hand tools and soldering iron.
    Schick Technologies Robeling NJ
    Bench Technician 5-1995 to 9-1999
    Loaded and unloaded previously setup machines such as arbor presses, drill presses, riveting machines and milling machines and over head cranes.
    Performed fastening force fitting and light metal-cutting operation on assembly line,
    Positioned parts in specified relationship to each other, using hands tweezers and tongs for surface mount application
    Read and interpreted blueprints and specifications to determine assembly sequence, tooling requirements, measurements and allowable tolerances.
    Marked reference lines and points on parts using templates and by measuring from blueprint index points and station lines using rule protractor and divider.
    Successfully managed a 11-person team assembling X-Ray tube heads
    Education:
    Penco Technical Institute Pennsauken NJ 2008-present
    PLC and Surface Mount Technologies associates degree
    Lincoln Technical Institute Pennsauken NJ
    Basic and Digital Electronics 1993-1995 certified
    Camden County College Blackwood NJ
    Automechaincs Class C, 1984-1986 certified
    Williamstown Senior High School Williamstown NJ
    Residential and Commercial Electronics 1980-1984 certified
    To whom it may Concern,
    Drew Harris had worked for me for several years and in that time Drew adequately displayed his abilities, which included but was not limited to, component level trouble shooting, writing test procedures, working with and without diagrams, schematics and drawings.
    Drew also displayed a high level of enthusiasm in our projects. His strong points were his professionalism, leadership qualities, organizational skills and good attendance. Drew also followed through with all his assignments and as a team player, helped others when needed.
    As a potential employer you will find the Drew will be an excellent addition to your work team.
    Brian Schwartz
    Production Supervisor
    Test Technology Inc.
    ey if U guys r hiring heres a copy of my resume
4 Suggested Answers
jdhankins11
SOURCE: RCA systemlink 3 universal remote (RCU300) codes
VERY DETAILED SITE:
http://www.parkwon.com/rcatest/rcafra.htm
Posted on Aug 17, 2008
SOURCE: code to program my remote systemlink 3 rca to my jvc televsion
Im trying to program my remote to my orion televisison how do i do that?
Posted on Jul 08, 2009
SOURCE: SYSTEMLINK 3 RCA UNIVERSAL REMOTE CODE 4 A MAGNOVOX TV
necesito codigos de control rca systemlink 3 para programar tv emerson y sylvanya,por favor ayudenme, gracias.
Posted on Nov 05, 2009
Re: need codes for rca remote Systemlink 3 for 22729 tv
Katina, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.remotecodelist.com/remotes/rca/rca_systemlink_prog.html
RCA universal remote code lists RCU Series Systemlink series direcTutor
Electro help RCA SYSTEMLINK 3 UNIVERSAL REMOTE TV SETUP CODE LIST SETUP...
Aug 19, 2016 | RCA Televison & Video
What is the codes for magna sonic MCT2051 tv
If you searched for a code using your Systemlink 3, it may not have that code in its library. Different programmable remotes have different codes stored. You may have to try another programmable remote.
Jan 03, 2015 | RCA Televison & Video
I need the tv codes for a systemlink 3 rca universal remote
There are no Coby TV codes in my Systemlink 3 instructions. You might try code search to find something that will work
Nov 13, 2012 | RCA RCU300 Remote Control
Need code # for rca tv
If your remote control has a search button, this is how you do it-------- User submitted information for the SystemLink 3: To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
  1. Press and hold the "Code Search" button until the LED lights, then release. LED will stay light.
  2. Press and release the device key to be programmed. LED will go off when button is pressed and back on when released. LED remains on.
  3. Press and release the remote On/Off (power) button as many times as required to turn your device OFF.
  4. When device turns OFF, press and release the ENTER button.
Test remote on device, if ALL functions do not work, repeat above procedure.
***IMPORTANT NOTE*** Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Nov 19, 2008 | RCA 3-Device Universal Remote with...
MY TV IS SANKEY AND I CAN`T FOUND THE CODE IN THE LIST OF MY SYSTEMLINK3 RCA, Please i need help! Thank`s
Nov 06, 2007 | RCA RCU300WBL Remote Control
RCA RCU300WBL Remote Control Logo
1,600 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
