Question about MSI 865PE Neo2-S Motherboard
It is a 865pe neo2-s motherboard.will not postor anything but shows signs of power to board. tried flashin bios as described on msi website. friend said that she was lookin to change boot order and hit flash start or start flast and turned off before finish. what could be wrong?
  • Anonymous May 09, 2009
    no leds
  • computerteen May 11, 2010
    looks like there is an issue is there any led diagnosic light stip on the mobo?
MSI 865PE Neo2-V Motherboard does not boot to BIOS. It just powers up and the drive lights are on continuously. Is there a replacement MB that uses essentially the same BIOS and won't require re-formating...
This one is pretty much identical
http://cgi.ebay.com/MSI-865PE-Neo2-P-Motherboard-P4-socket-478-EMS-/180572214688?pt=Motherboards&hash=item2a0af155a0
This one is similar but you will need to reinstall a new audio driver
http://cgi.ebay.com/MSI-865PE-NEO-2-Motherboard-Processor-/200552149636?pt=Motherboards&hash=item2eb1d6f284
Dec 09, 2010 | MSI 865PE Neo2-V Motherboard
What is the max ram that I can install in the 865pe neo2-p board
The MSI 865pe motherboard can use up to a maximum of 4GB of PC1600/2100/2700/3200 non-ECC DDR RAM
Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
Can prescott 800 mother support p4 2.4ghz/1m/533 processor
The MSI 865PE Neo2-PLS
Supports Intel® P4 Northwood/Prescott (Socket 478) processors.
FSB 400 (for Northwood only), 533, 800MHz.
Supports up to 3.2GHz or higher speed.
See page 1-2 in your manual. Also see page 2-3.
MSI supported CPU list; http://www.msi.com/index.php?func=prodcpusupport&maincat_no=1&prod_no=569#menu
Main link for 865PE Neo2 platform; http://www.msi.com/index.php?func=searchresult&keywords=865PE+Neo2
Cheers'
Mike
Jan 20, 2010 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Ethernet LAN not detect
Hello download the lan driver from here:
http://www.msi.com/product/mb/865PE-Neo2-P-Platinum-Edition.html#/?div=Driver&os=XP%2032
Try to renew the driver and install the new one.
And check your bios settings for the lan.
Good luck
Jun 02, 2009 | MSI 865PE Neo2-PFS Motherboard
Mother board cd
Hi quadir, you will not find a CD for your MSI 865PE Neo2-PLS board. You can order it from MSI or you can download the driver software by clicking on this link. http://global.msi.com.tw/index.php?func=searchresult&keywords=865PE+Neo2-PLS&table=download
This next site will open MSI to you're board. Suggest you add this to you're favorites.
http://www.msicomputer.com/product/p_spec.asp?model=865PE_Neo2-PLS&class=mb
To call MSI & order a CD click on this link.
http://www.msicomputer.com/company/contactUs.asp
Good Luck!
Have more questions, feel free to ask.
Mike
Apr 26, 2008 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Msi 865pe neo2-p (ms-6728)
well if thats so...theres only way and hope you can rebuild it...download from the official msi site www.msi.com.tw the bios properly for the board,make a bootable cd and under DOS mode try to rewrite it.
for now theres no bios in your board...
but I must say you...It is a huge chance that you did a severe damage to the board and may not be recovered..
however try the bios  like I said...
keep me up to date..I  worked a lot with MSI boards..I really want to know how you do it..
bye
Feb 09, 2008 | MSI /865PE NEO2 PLATINUM ED. Motherboard
MSI 865PE Neo2-S Motherboard Logo
87 people viewed this question
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
