Question about Alpine MRV-F345 Car Audio Amplifier
Mrv F345 power cut out and now the screen flashes blue
I have checked all the fuse's and everything is fine, when i turn the car on the speakers make this pop noice and the amp get's power but than the amp flashes blue.
any advice would be great
    Novelist:
  • 149 Answers
Disconnect all of the speaker wires at the amp and turn your system on -if the amp stays on then you likely have a roasted coil in one of your speakers somewhere and causing a short which is shutting your amp down into protection mode-if the amp wont stay on with nothing connected to it then you have probably roasted something inside the amp and uhhh good luck bro
Posted on May 09, 2009
Alpine mrv-f345 cuts off when...
Yes sounds like your not getting enuff power from the battery could be your alternator you should have it tested. Also have you try'd a capacitor? I put one in my car and it stopped cutting out...
Feb 05, 2010 | Alpine MRV-F345 Car Audio Amplifier
Alpine Amplifier Cuts in and out on Passenger side while driving
Make sure wirings are not pinched and try replacing the fuse as well.
May 01, 2008 | Alpine MRV-F345 Car Audio Amplifier
My mrv f345 amp reads CUR on display screen and has no sound.
That error appears usually when the speakers (especially subs) aren't getting the current they need from the system. Check your wiring and make sure you're using the appropriate gauge wire. Too small of a gauge in wire can cause this.
Sep 30, 2009 | Car Audio & Video
Fan not working
iT SOUNDS LIKE THE FAN IS NOT WORKING RIGHT, SO CHECK OTHERWISE IT WILL COOK YOUR AMP
May 16, 2009 | Alpine MRV-F345 Car Audio Amplifier
Wiring door speakers
Just make sure that the speakers are the correct impedance and properly rated. If not, the amp can be damaged.
Jerry G.
Apr 27, 2008 | Alpine MRV-F345 Car Audio Amplifier
Alpine MRV-F345 VLT ERROR
This is an indication of a voltage error, I have seen this when the voltage regulator or the car battery is begining to have a problem supplying enough current to the amplifier. Check the voltage levels with the amp turned off and then turn on the amplifier, if the voltage drops this means that there is poor voltage regulation and this may mean that you will have to replace the car's voltage regulator.
I hope this helps,
Thank you,
Shuttle83
Apr 20, 2008 | Car Audio & Video
Error code on alpine mrd 500
It's a current overflow in the system. You can also get this message if the voltage is too low. Also it can mean a short in the speaker cable. E3 Error is a general error "eccessive current overflow". Check the fuses, I believe there are 4 in this unit but not sure. Check your crossovers. I hope this helps you out. Is this a new hookup or did you buy anything new or change anything?
Jul 06, 2007 | Alpine MRV-F345 Car Audio Amplifier
Over heating
you trouble shoot the problem by opening unit and force-powering fans to test for overheating during "being used loud for a few minutes". Read the fans' label for proper voltage to apply and proper polarity. I am guessing the fans will run on car battery voltage of 12 volts. Also, attempt to close up the unit to simulate real conditions. There should not be fuses for the fans. If unit is now cooling, then look for faulty thermistor, which turns the fan on during rising temperature. Once thermistor is located, a fast test is to "jumper" its two wires to simulate turn on.
Jun 16, 2007 | Alpine MRV-F345 Car Audio Amplifier
this isnt a complex problem but both units may need service
Mar 12, 2007 | Alpine MRV-F345 Car Audio Amplifier
Alpine MRV-F345 Car Audio Amplifier Logo
317 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
