Question about Kitchen Ranges
Hidden bottom element not heating. Went to remove it and it had burnt through. New element doesn't get hot.
Hidden bottomm element not working removed it. It was burned right through. Put replacemnet in and it is not getting hot. What 's up?
    Scholar:
  • 43 Answers
Assuming that you installed the replacement correctly, can you check the element with a resistance meter?
It's possible the replacement element you bought was faulty. But first, we want to ensure that the oven is otherwise functioning correctly. You'll need that resistance meter to check continuity along the red wire (i'm presuming) that connects your top and bottom element to your selector knob. Also make sure there are no internal fuses in your oven that may have blown.
Please remember to turn the oven off at the breaker board before working inside it.
Hope this helps, let me know.
John
Posted on May 09, 2009
How do you remove the moulded Hidden Bake Element from the inside whirlpool ceramic range accubake system
first, remove power from the unit before doing ANYTHING! second, remove the back cover of the machine, this will expose another smaller panel with 4-6 screws in it running along the bottom edge across the back. after removing the screws you will have to gently BEND the panel down until you can see the wiring leading to the hidden bake element. cut the insulation covering the back of the element... be sure new element is placed in the exact location of the old one to avoid shorting the bake terminals to the metal cover, then reverse the removal process...
Apr 26, 2016 | Whirlpool 30" Self-Cleaning Freestanding...
There is no heat
This may sound a bit elementary, but have you cleaned the lint trap thoroughly? You'd be amazed at how many people don't. If so, it is probably your heating element. Remove the back panel (which is more work than you might think with the hidden welds, and bottom screws). You will see the thermostat hanging off the heating element. Carefully run the machine without touching the unit at all, and see if you can feel any heat emanating off of the element. That will tell you right away. It's a relatively easy, and inexpensive repair.
Jan 17, 2010 | Dryers
Replaced both elements, both thermostats. What else could it be?
no hidden switches!, did you replace bottom elements? and thermostats? one hint...bottom element heats first, then top...never both at one time.
Mar 24, 2009 | Kitchen Appliances - Others
How to change hidden element in kitchenaid oven
you have to remove the plate that covers that element
Jan 03, 2009 | KitchenAid Kitchen Ranges
Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Jun 18, 2008 | Dryers
How to replace a fan bake oven hidden element
Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
Oct 25, 2007 | Fisher and Paykel AeroTech - OS302M...
Kitchen Ranges Logo
235 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
