Question about Electric Stanley Tre500 Staple Gun / Sharpshooter
Loading spring came off
Spring in the handle came completely out
Which fridge compressor is best for a vibrating environment
compressors are normally mounted on rubber grommets to reduce noise through vibration but I have seen many with small coil springs in the mounts to absorb the vehicles vibrations
you may have to get a refrigeration fitter to fit flexible hoses to the compressor to prevent line failure through the compressor movement
the other solution may be to mount the complete unit on a spring loaded suspension base
Jun 29, 2017 | Refrigerators
Finding a linkage diagram for a american yard pro mdl#hwsp2525b from mower handle to briggs & stratton mdl#12c802-0816-03 engine
1 cable goes to the deadman's handle to a silver spring loaded lever on the mower that the spring is stretched when handle is against upper mower handle. The other cable if equipped goes to carb for speed control.
Jun 07, 2016 | American Yard Products Garden
WhenI let go of the safety handle the mower will not turn off unless I let go of the handle slowly to a certain spot and then it will turn off. Any suggestions? Thanks Dave
if you follow the cable to the engine look at bracket you will see the mechanics of the emergency shut off and look close there will be a white clip with a black wire under it the clip is spring loaded push up on clip the wire comes off clean and reassemble make sure the clip is touching metal when the handle is not held down if not adjust so with handle completely released the metal part of the white clip touches metal there you go have a great day
Apr 25, 2015 | Troy Bilt 5.5hp Self Propelled Mower
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
How to load Arrow T25 Staple Gun
at the back end of the handle, there is a retainer spring loaded clip. Push it in, then push it downward toward the base of the stapler, the clip should then release the spring, pull the rod with the spring completely out, slide a row of staple in where the rod came out, ONLY ONE ROW, then insert the rod with the spring back in and push it firmly in, and lift it upward to engage the lock. and fire away... Hope this gets your working
Jun 08, 2009 | Arrow T25 Staple Gun
Black&Decker Cord Electric Mower
im not all that familiar with electric machines - without having the machine in front of me i prob cant help much sorry
Nov 02, 2008 | Electric Lawn Mower
Whirlpool replacement door handle and spring
Since this has received no response, I am closing it off my list. If you need any other help drop me a note back.
Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Electric Stanley Tre500  Staple Gun / Sharpshooter Logo
20 people viewed this question
Top Electric Tools & Hardware - Others Experts
eddie_brown
Level 1 Expert
Mike Carew
Jim London
Jim London
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
