Question about Pool & Spa
I need to change a fuse on Ecco B580 spa where are they located
Under What panel on ECOO 580 spas are the fuses located. We need to change the SC25 fuse.
  • 1861 Answers
SOURCE: 2006 Toyota Matrix 2nd fuse panel location?
The second fuse panel that you seek is under the dashboard, on the driver side (for a US car). This box is called the "JB1" (junction block #1), and contains several relays in addition to the 15 amp "CIG" fuse that you need to replace.
Hope this helps, and thanks for choosing FixYa!
Happy Thanksgiving!
Posted on Nov 25, 2008
motor1258
  • 6674 Answers
SOURCE: 1998 plymouth grand voyager cruise control relay/fuse location?
Check under hood in box marked fuses & relay, on drivers side and look under cover of it for I.D.
Posted on Apr 11, 2009
SOURCE: can not locate fuse box under instrument panel
I spent a good hour trying to find the "instrument panel fuse box". I almost started ripping the wrong stuff off. Think they could have stamped it to identify it a bit better?
You must open the door, it's right there on the side. It doesn't look or feel like it should come off (piece with a vent hole of sorts). You have to really reef on it, it does come off.
Probably get a little needle nose pliers for getting the fuses out now.
Posted on Oct 06, 2009
BCAS1298
  • 3092 Answers
SOURCE: Underhood fuse panel on a 1994 Chevrolet Suburban K2500
Under the hood driver side close to the master cylinder and fender, has black cover , pull cover off.Hope this was helpful.
Posted on Dec 15, 2009
  • 172 Answers
SOURCE: fuse box location case 580 l
The fuse box will be on the right side of the machine if you are sitting in the seat facing forward. Where the sheet metal goes out to meet the fender there will be a square panel held on with 2 or 4 screws. The fuses are located behind that panel which faces forward.
Posted on Jan 22, 2010
Spa wont turn on,there was a lightening strike.could that have ruined the spa
check the GFIC trip it and reset it, next see if any lights come on in the spa. if no you might want to check for voltage at the spa, if you have the set voltage 115 OR 230v . I would check fuses on the control panel .
Hope this gets ya running again. ask if you need morwe help, and don't forget to vote if i was of help
Nov 18, 2014 | Dream Maker Spas Pool & Spa
My dream maker escape spa 8003 has no power. Almost seems like a fuse, but I can not find a fuse.
check breaker if ok fuse inside panel of controller if bad check recirculation pump or heater element
Oct 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream maker spa blank panel
if power check display or transformer also check fuses
Jul 01, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Our spa quit running one day and we have not been able to get it to run again
There are a number of fuses inside the electrical panel. Disconnect power to unit and with a multimeter, test each fuse after removing it from its holder.
Feb 17, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
The pump on my EZspa will not turn on.
Turned out to be a fuse, contacted the local dealer directly and they said dreammaker has changed vendors on the control box unit and
they have been having problems with the 250V 15Amp fuse.
Suggested that I go to a 20Amp, but that I should contact dreammaker
directly
Jan 02, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Fuse box location case 580 l
Oct 04, 2009 | Milwaukee Tool Case Heat Gun
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
