Adding a wired computer or device to the network.
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you are adding a desktop or any other device to the router which will always be connected to the router with the Ethernet cable, then in this case you don't need to do anything.
You can just connect the Ethernet cable between the router and the computer and it should work.
If you are not able to go online even when it is connected properly then check IP address of the computer.
Adding a wireless computer or device to the network.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
click Here for step by step instructions
