Question about HP Computers & Internet
Corruption in feature manager settings Every time I sign in I get an error saying "Corruption in FeatureManagerSettings. Trying to figure out how to solve this.
No memory card error
You need to change the memory card with new one, because memory card got corrupted and needs replacement.
Thanks
Feb 24, 2012 | Canon PowerShot SD1000 Digital Camera
Tip
Fix Windows 8 Error 10
The TIPS this article will help you get detailed diagnostic information and fix the error 10 in Windows 8 operating system.
Update Malfunctioning Drivers
Update the drivers for malfunctioning devices indicated with a yellow color exclamation mark.
gDz7TRY2sKy0361Sog6d_QRTmWz6S9-nl9X3yA0HIer5Haj_GQ5bV5l4qGjSNXSfX4ooWo_pbQ6262sUBB851TJtcW-Pgq_lfLjbzlCXBboCmW3twhWYyUDEwcIg" width="560px;" height="671px;" alt="Charms-Bar.png">
1. Press Windows Key + C.
2. The Charms Bar will be displayed.
3. Click the Settings icon.
4. Click Control Panel.
5. Click System and Security ' Administrative Tools.
6. Double click Computer Management.
7. After Computer Management dialog opens, expand the top root node, i.e. Computer Management (Local).
8. Expand System Tools node. Select Device Manager.
9. Yellow colored exclamation mark will be displayed to malfunctioning devices. Right click a device and select "Update driver software".
10. Follow the on-screen instructions.
Reset Internet Explorer Settings
Set the default browser settings.
6QpjEtDk8qJZs2mphJj-3-XktdOeYcnxtYFj11QQB9Xqb-p3l-thAWDgoVOpbENPhFwNwUnj-6qwJLTcXdFxvBp2jD4bP8Qxz5dblvcliY5Di5F8-Ju8sgiPg8xw" width="624px;" height="376px;" alt="Reset-Internet-Explorer-Settings.png">
1. Press Windows Key + X.
2. Select Command Prompt (Admin).
3. Type "inetcpl.cpl"
4. Press ENTER.
5. Internet Properties dialog will open.
6. Click the "Reset" button and confirm the action.
Change the Security Zone Settings
Go to the Security Zone settings and set appropriate levels for the Internet, Local Intranet, Trusted Sites and Restricted Sites zones.
AawqQhUftQ2Jr4EB1hN7dlsse5wSRe6YYQg1V7o0y6pPCnq1_hqiYQuJHHh7OcLoIV9ZopXEJfL3ieBFbaKIZhUP2I7N056B1fStHbuuudMooR6Vp9Jf0IigkTWg" width="423px;" height="542px;" alt="Internet-Options.png">
1. Open Internet Options dialog. (Refer Steps # 1-5 from Reset Internet Explorer Settings paragraph)
2. Click the Security tab.
3. Select "Internet" icon.
4. Move the "Security level for this zone" slidebar to Medium-High.
5. Click "Local Intranet" icon.
6. Set Medium-Low level for this zone as in the Step # 4.
7. Click Trusted Sites icon.
8. Set Medium level as in the Step # 4.
9. Click Restricted Sites zone and set High level for this zone as in the Step # 4.
10. Click Apply, and then OK.
Delete the Browsing History
Every time that you open Internet Explorer corrupt history is loaded. Delete the browser history to fix Windows 8 error 10.
XDtvYecmugRcsb198KaB0YszDRSi1mGcxY-wpowd_jfyYmqawXrtuuTFZH54IAsNi0v4UUW-2gJD_U9ytRKvDgAemkWIOA25IhmJckjLYMKwZF79ooH8bblZQfOw" width="624px;" height="332px;" alt="Delete-Browsing-History.png">
1. Open Internet Explorer.
2. Press the Alt key of your menu bar.
3. Select Tools ' Delete browsing history.
4. In the new dialog check-up all the checkboxes displayed.
5. Click the Delete button to start cleaning the Internet history.
Disable the Smooth Scrolling
Smooth scrolling feature may not work properly due to graphics issues. Disable the smooth scrolling feature to prevent this problem.
2. Click the Advanced tab.
3. Scroll down the scrollbar. Under Browsing category uncheck the "Use smooth scrolling" checkbox.
4. Click Apply ' OK.
5. Exit and re-open the Internet Explorer.
Turn Off Hardware Acceleration
Many applications use the hardware acceleration feature. Disable the hardware acceleration and check whether it helps.
qBTFDPo49_raes7y1knOMykZeW33CJRJ7QDmYryXT2oBZ3ZyVLy4pZPxgWA5L2yDsPwSbFizWYppPUn2MNFY-OLGuLnWimun1HJmmBjRP7s3RnzyBFnkKyevZadA" width="624px;" height="435px;" alt="Display-Settings.png">
2. Select Search option.
3. Type "desk.cpl" in the Search Box.
4. Click the Apps icon and open it from the Search Results.
5. Screen Resolution dialog will open. Click the "Advanced settings" link.
6. In the subsequent dialog click the Troubleshoot tab. If that tab does not exist it means your graphics card does not support the hardware acceleration feature.
7. Set Hardware Acceleration= None
8. Click OK ' OK.
Reregister Problematic DLL
Reregister the system file named rasppoe.sys using Command Prompt.
k_C1fljiI30RqbQr0RcDaLI67Bnrxyc-t2BAynOldOVABPjSCHobXaDc9h4wPhKwG41xuthC1yEtgpkeE1mYd4z5GscwbRq8KvN_bm07yrrMJt8RTD8v87VsgLsw" width="624px;" height="316px;" alt="Register-DLLs.png">
1. Press Windows Key.
2. Type "CMD" in the Search Box.
3. Click the Apps icon.
4. Right click the "Command Prompt" icon in the Search Results page.
5. Click the "Run as administrator" icon at the bottom of the page.
6. Type the following command:
Regsvr32 rasppoe.sys
7. Press the ENTER key.
Rename Problematic DLL
If there is any problem with the rasppoe.sys it will be resolved after renaming the file.
1. Double click Computer desktop icon.2
2. Open the following location:
C:\Windows\System32\Drivers
3. Rename "rasppoe.sys" as "rasppoe.sys.old"
4. Restart your computer.
Turn Off the Software Rendering
If the software rendering feature is not supported, simply disable it.
1. Open Internet Explorer dialog box. (Refer Steps # 1-5 from Reset Internet Explorer Settings paragraph)
3. Uncheck the checkbox named "Use software rendering instead of GPU rendering" under "Accelerated Graphics" category.
Change NVIDIA Graphics Settings
Go to the NVIDIA Graphics Settings and uncheck the Stereoscopia 3D setting.
Reinstall Flash, Java & Silverlight
Uninstall and reinstall these three programs to check whether program files corruption was an issue or not.
ueHytD4giGWOXrR_3IWKFfhwbQ9jzLmwUo4vkrzaGnQ4codvWpaKLAD2mWNh7vMHYdPxG-1cgfa91Bj_oMXCyeJ65-x4gMobvJBCNBR6fFp7rDxkurxoAbK5nahQ" width="624px;" height="435px;" alt="Programs-and-Features.png">
2. The Start Screen will open.
3. In the Start Screen type "Uninstall a program" in the Search Box.
4. Click the Settings icon.
5. Open it from the Search Results.
6. Right click a program name and select Uninstall option. Uninstall the Flash, Java and Microsoft Silverlight.
7. Download the above programs from the Internet.
Change the Environmental Settings
Change the values of Environmental Settings in order to fix Windows 8 error 10.
8yve5KFc4UjrHg0s4dJHlHctnOeiBs9cI9FSVHoa0nsfecop4N8kbc2ccl8bOHdcsetF6ZIhLA3L_WGSsmOnR6gM4rolUg8o5-YeAfTEMMSXhOBjT8nWUqBR0XpQ" width="397px;" height="439px;" alt="Environment-Settings.png">
1. Right click Computer desktop icon.
2. Select Properties from the context menu.
3. Click "Advanced system settings" link.
4. System Properties dialog will open.
5. Click the Advanced tab.
6. Click Environment Variables button.
7. Under "User variables for " category two temporary folders will be displayed.
8. Select the "TEMP" folder.
9. Click the Edit button.
10. Specify Variable Value: "C:\Tmp" (without quotes).
11. Click OK ' OK ' OK.
Fix Issues in Registry
Often errors in Windows registry result in such problems. It is wise to keep Registry cleaned from corrupted entries. To fix Windows 8 registry, use the Intel Software Partner Reginout System Utilities here: RegInOut System Utilities
on Nov 24, 2014 | Microsoft Computers & Internet
I am using my mother's Elgin 3400E travel alarm
On my Elgin alarm clock, you just push the nap button and it will add 15 minute increments for a nap. I haven't figured out how to turn it off if I change my mind or wake up earlier than I set it.
Jul 21, 2011 | Elgin Travel Alarm Clock
Half of the time I take pictures, it says "unidentified image" on the picture when I try to look at them.
Hello
This is a sign of image corruption. First culprit would be your memory card. Please acquire a new one and use that. In the rare chance that you continue to receive this error message, it will point to the camera as being the culprit and it will need to be sent in for service.
Mar 11, 2011 | Canon PowerShot A3100 IS Digital Camera
When i turn on my phone, the screen becomes white and it shows which read " JVM error 192" in the next line it only shows which read " reset" Moreover, I had been getting low...
JVM errors are caused by the corruption of Blackberry handheld software.You'll have to reload the Blackberry handheld Software using Blackberry Desktop Manager.
Feb 22, 2011 | Cell Phones
Im getting a MySQL error saying : "Exception EMyxError in module MySQLQueryBrowser.exe at 00111E52. Error while loading stored connections. Error Number 3."
I think your MySQL Server databases got corrupt.
Try to remove or rename your existing connection file, creates a new one if it does not find any existing, allowing so to recover from broken files from the utilies below-
MySql Fix Toolbox provides easy ways of MySQL fix
Worried for Losing Data due to MySQL Corruption
Dec 27, 2010 | Computers & Internet
How do I fix the pop up that says corruption has been detected in Feature Manager?
i have e dell latitude. a have forgotten my password. how to remove this password
Jul 01, 2009 | Dell Computers & Internet
Feature Manager Pop up & back up file has been loaded.
I received a pop-up that said, '' Corruption hads been found detected in Feature Manager, back-up file has been loaded. Sierra Wireless Aircard 881 Most of the time you can repair the feature file by opening and closing AT&T Communication Manager (ACM). If that doesn't work try this... 1. Close ACM. 2. On you computer browse to C:\Documents and Settings\All Users\Application Data\Communication Manager. 3. Delete the files called featuremanager.xml.rc4 and featuremanagerBackup.xml.RC4. 4. Open ACM. 5. If your still having the problem delete the entire Communication Manager directory in Application Data. 6. Uninstall and Reinstall ACM.
Try this and let me know if it helped you Thank you, Techlahj
Jun 07, 2009 | Computers & Internet
I keep getting an error message when I start up my laptop. the 2 wire gives me a "corruption has been detected in feature manager, backup file has been loaded", and it will not connect. All other programs...
If the machine is a Dell with DellControlPoint, open start, run then type msconfig and hit enter. Choose the Startup tab and find the startup item named "Dell" with the Command from "C:\Program Files\Dell\Dell Control Point\Connection Manager\Dell.UCM.exe" and uncheck the box. Hit Ok, then reboot your computer.
Jan 16, 2009 | Computers & Internet
DRM Software Corruption
Nice. That worked great.
Thanks for posting.
Jul 09, 2006 | Rio CE2100 MP3 Player
Computers & Internet Logo
1,192 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
