Question about Panasonic CT-32HX41 32" TV
Wont turn on
When i push the power button i hear it turn on and then the red light appears, i hear click click click and then it automatically turns off this will happen every time i try to turn it on.
    Genius:
  • 1,139 Answers
Hello zang,
This denotes a problem with the switching power supply or the high voltage power supply. what is happening is the safety relay is being actuated by the shutdown circuit. Any number of things can cause this proble but more then likely the problem is in the high voltage power supply section and or its associative circuitry. The switching power supply and the high voltages power supply have very dangerous voltages and I would not suggest that you work on the TV set unless you do have a background in electronics. If you do not I would suggest that you take the TV set to an electronics shop for repairs. If you do have a background in electronics, you will need the following items:
1) A schematic diagram (to know where voltage and signal test points are located and to have a reference of the levels.
2) A multimeter (to measure the DC voltage levels on the TV Set)
3) An oscilloscope (to measuer the AC voltage and signal levels in the TV set and compair them to the values in the schematic)
4) A signal generator (to generate a reference signal for troubleshooting)
I hope this helps,
Shuttle83
Posted on Oct 11, 2007
SOURCE:
My LG Plasma 50PK550 doesn't show a picture when I push the power button. It will also shut off when I push either the Input or channel buttons.
Main digital board fault. Check and replace the main digital board. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 27, 2017 | LG 50PK550 50 HDTV Plasma TV
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Screen wont come on
Hi Rita
I would recommend for you to turn the iPad off completely and restart it. To do this you push the power button in the top right until "hopefully the red "swipe to turn off button" appears. If this does not happen we will have to perform a hard reset and the way to do this is to push the power button and the home button at the same time for about 10 seconds. The iPad may restart automatically however if it does now now you can push the power button in the top right and the Apple Logo should appear at the center of the screen.
Now your iPad should start up freshly and come back to life, unless there isn't a further problem.
Dec 07, 2013 | Apple iPad (16 GB) WiFi Tablet PC
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
May 16, 2009 | Pioneer VSX-305 Receiver
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
RCA Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. If you push the menu button after awhile the red light will stay on and not blink....
Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. Eventually the red indicator light stays red. Tried unpluging set. Is it the EPROM ?
Jan 19, 2008 | Televison & Video
ESA 42" plasma will not turn on
Find a power supply that was the problem with my. Exept my tv now dont have picture Cause ysus board is dead..
Nov 10, 2007 | Televison & Video
TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic CT-32HX41 32" TV Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
