Question about Gateway 500 X PC Desktop
Wont connect to start anything
Wont connect to internet just keeps showing hourglass running desktop is up but cannot do anything else can only shut down by turning tower off manuallly
  • froggellie May 09, 2009
    i am using windows XP it wont click to open anything
  • Anonymous Mar 20, 2014
    tower turns on screen comes on to main start screen but egg timer on and every thing frozen can't shut down or open anything
    President:
  • 1,335 Answers
Which operating system are you using?
go to Start, Control panel, network to see if your connected to the internet.
Posted on May 09, 2009
  • Bob Kitaji May 09, 2009
    When you say that "it wont click to open anything", are you saying that you cannot run anything off the desktop or start menu?
  • Bob Kitaji May 10, 2009
    It sounds like you need to start from scratch. You may have to start from scratch, meaning you'll have to do a format of the hard disk drive and reload a clean copy of XP and then reload any drivers for your peripherals.
I have a compaq presario SR1303 Wm Desktop I wont connect to internet, stating that local area cable is unplugged, however this isn't true because I have another desktop same model that works fine...
If all looks good try right clicking on network status icon in sys tray and use repair. A more advance option would be to use ipconfig from the command prompt.
Start > Run (search in Win 7) > type ipconfig /release. Then ipconfig /renew. ipconfig ? will show you all the options. Good luck.
Aug 31, 2012 | HP Compaq Presario SR1303WM (PP150AAR) PC...
When I turn my Samsung VRT front loader on, the hourglass will not go off and washer start.
I am having the same issue as well i.e i can set the cycle but the washer wont start (the hourglass Icon remains lit). If i press the off button. The display shows off but the display doesnt shut down. Thought this might a control board issue. Bought one off of ebay & replaced it. Did not make any difference (p.s the machine is outside of US so calling service is not an option).
Jun 19, 2012 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
New dell vostro 260 wont connect to internet
if it is not showing a connection check to make sure that your modem is working properly, try resetting the modem plus it your internet service provider gave you a disc please run it so that it can download the proper drivers for your modem so that it can connect to the internet.
Jun 08, 2012 | Dell Vostro Computers & Internet
When I turn on my kids computer, the desktop comes on, but the taskbar won't load & when I hold the cursor over where the taskbar should be, it shows the hourglass. The same happens if I hold it over...
perhaps its a simple viewing issue -- the task bar can be dragged into whatever corner you want it and it is hiding on you or it may not be sleceted .
try going to CONTROL PANEL, clcik on TASKBAR & START MENU, review the choices you see there and slecet whatever one you prefer.
hope this helps
Oct 19, 2010 | Computers & Internet
Keep loosing my internet connection when I have
Isolate the problem if you can by using a laptop on you Internet connection and see if it stay connected. If your PC is fully updated with the Microsoft Patches and you believe you are Virus and Malware Free... it could be the Modem from WildBlue. Since it is a Satilite system, you should have support with them to run a Diagnostic.
Dec 31, 2009 | HP Computers & Internet
Blackberry curve 8310 fatal error during backup
I would connect the device to a PC and update the OS using Desktop Manager. If you recently installed any application, I would uninstall it as this may cause this type of behavior.
Jul 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
Acer laptop won't open programs when turned on. Hourglass stays stuck on screen
Sounds like a registry or memory problem. Try doing a system restore in safe mode to a earlier time and see if that works. If not it may be a memory problem. If you can get it up in running in safe mode try shutting down some of the not needed start up programs by going to run and type "msconfig" without the " " and click start up and take out all the excessive stuff.
Joe
May 19, 2009 | Computers & Internet
Keep losing wireless network on laptop. completely disappears and can not find it to reconnect
Hi..
I was having the same issue with my notebook. I was losing connectivity to the internet at both home and office through my browsers and outlook consistantly after boot up for approximately 10 minutes. The only way to get more connectivity was to reboot my machine (ten more minutes). Emachines help desk was no help. Their fix all response was to format the harddrive and start over. What I did to fix it was:
Start
Control Panel
Network Connections
There, I disabled the wireless network connection and waited for the hourglass to go away. Then reenabled it and have had wireless connectivity since.
Good Luck ;-)
Dec 04, 2008 | Computers & Internet
AOL Hourglass
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors.
Try AOL again.
If AOL is still not working...
Un-install AOL.
Shut down completely for at lest 30 seconds, then restart.
Then do a search for all AOL files and folders with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those found.
Restart then run Registry Mechanic again.
Shutdown restart.
Reinstall AOL.
Sep 11, 2007 | Computers & Internet
Unit wont start up after power failure
Answer on fixyourownprinter.com. Search there to see how to lubricate rod under scanner glass. Common fault. Mine responded instantly starting up fine after rod lubrication which stops scanner initialisation routine and leaves you looking at hourglass.
Jul 30, 2006 | HP PSC 2510 All-In-One InkJet Printer
Gateway 500 X PC Desktop Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
