Sharp ay-x095e timer flashes
2 Suggested Answers
SOURCE: Our Sharp inverter air conditioner
Did either of you solve your problem as I have the same problem with my Sharp unit
Posted on Feb 18, 2010
Sharp AY-XP 12 ER indoor inverter showing -0 14 error
Sharp AY-XP 12 ER indoor inverter showing -0 13 error
Sep 11, 2013 | Sharp Heating & Cooling
Sharp AY-A249J Split System Air Conditioner not working, the timer light flashes 5 times and the power light does not flash at all, the remote has limited function, it turns the indoor unit on and off and...
Thanks for your replies, I had a Sharp authorised tech look at it and im told it's the indoor circuit board. Im told its a $360 repair job all up, that sure beats replacing the entire ac or putting up with the heat...
Dec 07, 2012 | Sharp AF-S120FX Air Conditioner
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
I have sharp mini component system cd-sw300h and can not switch the machine on . The timer light is flashing but I cannot seem to get the unit to turn on at all.
My sharp mini component CD es777 won't work. it only flashes a red light where timer is. I tried the remote timer but still no luck. Help
Apr 29, 2011 | Sharp Shelf System Shelf System
TIMER LIGHT BLINKING AND POWER IS NOT COMING ON CD-SW330
i have the sharp cd-sw330, it has no display and won't turn on but the timer just keeps flashing, i have done the bit it says about pressing the timer button then arrows and memory but that doesn't seem to work help?
Jan 09, 2011 | Sharp CD-SW330 Shelf System
Hello I have Sharp Air con/Heating AY-XPM9FR with a floor/wall unit and a higher wall unit that are supposed to work in conjunction with each other. I have never had any problems until we had a power cut...
Hi Helen, i want to know the age of your Sharp Air con/Heating system. If its more than 1 year and you using it regular basic , then i suggest you change the battery or the remote control first then try . If the same thing happens then follow the instruction as per below image.
If there is also ok & look good then ,please call a service man and check the air cooling/ heating gas. Because you mentioned "I have the manual and have tried to reset the timers using the remote control but still no good. " Another chance you can take before call the service person, just reset the full system by remote control not only the timer. Thanks & waiting for your feedback.
Feb 18, 2010 | Heating & Cooling
Walang image na lumalabas kapag nag capture ako sa digital camera ko,ang unit ay canon powershot a470
Ang isang mapagmataas panangga sa bintana ay isa pang karaniwang mode kabiguan para sa mga digital na kamera. Ang mga sintomas ng isang palalo o "malagkit" panangga sa bintana ay halos katulad sa kabiguan CCD imahen sensor. Ang kamera ay maaaring tumagal ng itim na mga larawan (para sa mga panangga sa bintana mapagmataas sarado), o ang mga larawan ay maaaring masyadong maliwanag at overexposed, lalo na kapag kinuha sa labas (para sa mga panangga sa bintana mapagmataas bukas).
Upang kumpirmahin ang isang mapagmataas panangga sa bintana, ilagay ang kamera sa anumang paraan maliban sa "Auto", at patayin ang flash OFF (hindi mo nais na bulag ang iyong sarili para sa susunod na hakbang). Susunod na tumingin pababa ang lens at kumuha ng larawan. Dapat mong makita ang isang maliit na maliit andap sa gitna ng lens bilang panangga sa bintana ang nagbukas at magsasara. Kung kilusan walang nakita, at pagkatapos mong malamang na magkaroon ng isang mapagmataas panangga sa bintana. Kung gayon, maaring tignan ang link na ito para sa karagdagang impormasyon at isang simpleng maayos na maaaring makatulong:
Ngayon A470 ay hindi kaya ng pagkuha ng 15 segundo exposures bilang inirerekomenda para sa ayusin. Sa halip na subukan ang mga setting ng kamera sa manual mode, patayin ang flash, got sa isang darkened room, at kumuha ng larawan. Buksan ang pinto baterya habang ang pula at dilaw na liwanag ay flashing. Kung pagkatapos ng maraming sumusubok na ito ay hindi gumagana, at pagkatapos isaalang-alang ang pagsubok Ayusin # 5a sa site. Subalit gawin ito sa kamera ang pinatay at ang lens retracted upang bawasan ang pagkakataon ng damaging ang lens na mekanismo.
Jan 24, 2010 | Canon PowerShot A470 Digital Camera
Sharp AY-A249J air conditioner not cooling
Maybe get an electrician to make sure the voltage is not dropping to low at start up.
Jan 14, 2008 | Sharp AF-S120FX Air Conditioner
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
