Question about Thermador PD486GLBS Dual Fuel (Electric and Gas) Kitchen Range
Small oven blue lights alternate - Thermador PD486GLBS Dual Fuel (Electric and Gas) Kitchen Range
When replacing fan oven element lost wires down back of oven
Best to turn off oven power at circuit breaker. Grab a strong torch and a wire coat hanger. Straighten the coat hanger and make a small hook on one end. Using the torch light guide the coat hanger loop towards some part of the wire and slowly fish it out.
Hope this helps. Otherwise you will be left with no alternative but to pull oven out (heavy) to access the side cover and remove it. It would be helpful to know the make and model of the oven if you needed more help with getting to the wire itself.
Aug 29, 2014 | Ovens
Whirlpool model SF3020EKQ3 was converted to LP oven lights nice blue flame but flame is very small oven does not get hot enough
HI,
If your able to adjust the orifice hood to the oven, then turn it counterclockwise unit the burner is full and minimal yellow flickering is present. If you go too much, this can be deadly can cause carbon monoxide to admit into the kitchen during use. I have found adjusting while the burner is on is the easiest way to make sure it is correct, use caution....
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 23, 2011 | Microwave Ovens
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Sep 12, 2010 | Microwave Ovens
Lynn would like to know which terminal on alternator is d+ for blue wire
It's the small terminal, below the larger terminal, there should be a black plastic wire guide. On the left side of the alternator when looking at the back of the alternator.
Mar 06, 2010 | 1986 Volkswagen Jetta
Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
We have a Thermador PDR484GG with flashing blue lights!!!
one thing i found with the little blue flashing light is the main board in the back of the range not fun
Jul 01, 2009 | Thermador PDR304ZS Dual Fuel (Electric and...
WD 500 GB Hard Drive just stoped working, It has the alternating blue lights in front, now as soon as it powers up it turns off - the alternation blue light don't even come on I still had 316 GB left on...
I had the same exact problem for a while and I think it's a problem with the slot where the USB cable connects to the HDD. I eventually just took a small knife and pushed in the metal tabs around where the cable connects as they were pushed out from the cable being pulled at random angles before. Somehow it works perfectly now, so I guess it just wasn't detecting a computer or in this case an xbox and automatically powering down to save electricity and heat. Anyway I just thought I'd share my experience, good luck with your HD!
Dec 14, 2008 | Computers & Internet
Thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Thermador PD486GLBS Dual Fuel (Electric and Gas) Kitchen Range Logo
15 people viewed this question
Top Thermador Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
