Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman push mower won't start
Mower turned upside down to replace blades. Engine is B&S 6.5 Hp. (Easy-Start).
  • 2 more comments
  • James Howell
    James Howell May 17, 2014
    J.D. Thanks for detailing the process. Actually, the mower was a Snapper Model 215012, with a B&S engine. I dumped it while mowing a steep incline, (no injuries). I really would not want to try this locatiion with the Craftsman riding mower. At least it should be easier to fix the push mower.
  • J.D. Browning
    J.D. Browning May 20, 2014
    i used to have a special gismo for cutting steep hills , sadly they don't make em anymore it was called a Flymo it was basicly a flying mower that i removed the handle from and tied a rope to ,easy to stand at top of hill send it down yank on rope bring it back up send it down again ,did the whole hill in few minutes and ya never needed to climb down the thing
  • James Howell
    James Howell May 21, 2014
    J.D. That's one of those things that's so obvious once you hear about it. Thanks again. I might just try that once i
  • James Howell
    Continued from last post: once I get the mower working.
  • Craftsman Master
  • 2,760 Answers
OOOh I don't recomend turning any 4 cycle engine upside down for any reason , i'll bet the starter won't even turn it over now, 1st your gonna need to replace engine oil to proper level , second your gonna need to locate valve (locker) this canbe ident by a small tube comming from it to carb , remove this cover and clean/drain oil from here and last remove spark plug tilt engine that direction and remove as much oil as you can attempt to turn engine over with key off by hand or with jumper on starter several times to get it moving again , clean plug with solvent and reinstall , also reinstall valve cmpt cover and tube , attempt to start might take several tries to get fresh fuel over to cylinder to fire or you might need to reclean plug several times
Posted on May 17, 2014
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Posted on Mar 12, 2009
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
  • 10865 Answers
SOURCE: i have a 18.5 hp 42
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Posted on Jun 08, 2009
wadembly
  • 489 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
How to start a Craftsman 20 hp riding mower?
Your question is mighty broad, but I would start at the battery, making sure you have a fully charged battery. Sit in the seat and push the brake pedal down. Make sure the blade engagement clutch is off or the lever to move the deck up and down is in the up position. Unless a safety switch is defective, the mower should start. If you just hear a click, you have a dead battery or loose wire. Until you get more specific, this is the best I can do.
Jul 20, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
What causes my 13.5 hp craftsman model #917270412 engine to die when i release the clutch
My question would be what caused the belt to break. Have you checked under the mower deck to make sure the blades turn freely? Could be that something is jamming them and causing the motor to die. Or even a blade that hit something hard might be bent against the top of mower deck.
May 07, 2014 | Garden
I have a honda gv100 lawn mower and there is no petrol going to the engine
I have a mountfield omega petrol lawnmower with a gv100 honda engine. I turned it upside down to replace the blade and now it won,t start. Any help would be appreciated
May 30, 2010 | Honda 8 HP Engine
I need to replace the two 21-inch blades on my Craftsman rideable lawn mower.
I just watched the service technician change mine. He pulled the rear differential release out, then after removing the hood, he put a hoist on the front and stood it upright on it's rear wheels, and easily replaced both blades with a socket wrench. That beats all the work of removing the deck and turning it upside down.
Apr 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I need to find mounting bolts, blade to shaft
Do you meanengine mounting bolts, blade boss, and 'Operator Presence Control' cable? If so, they are generic parts - not specific to your mower. I have no idea why you are having problems ordering them - they are consumable parts, and should be stock items for ant garden machinery repair outlet.
Aug 06, 2009 | Craftsman Garden
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
98 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
