Question about Watches
Pulsar NX14-001 buttons won't work to reset digital functions.
After a battery replacement (the analog hands quit moving), the A button will not operate to allow me to reset the digital portion of the watch (i.e. month, date, "Home" time zone, etc.
  • 13433 Answers
SOURCE: Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
  • 5 Answers
SOURCE: Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Posted on Feb 19, 2009
escapement
  • 2334 Answers
SOURCE: Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Posted on Mar 14, 2009
  • 4 Answers
SOURCE: changing analog hands / time function due to daylight saving time
Download the manual from
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Posted on Mar 24, 2009
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Posted on Mar 25, 2010
Do I reuse 2 batteries for my Umbro chrono watch?
Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
Let me know if ur watch is working successfully:)
Jan 27, 2017 | The Watches
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
Ul 1008 analog portion does not work
Are the hands moving but out of step with the digital display?
If so then try pressing the "mode" button to reach a mode that allows you to set the hands (on my Casio it is "HS"), I would expect something similar on yours.
You can then alter the hands by pressing one of the other buttons. I would expect one button to advance the hands and another to ****** them.
Happy experimenting!
Feb 22, 2010 | Kenneth Cole Watches
I have a Pulsar Analogue & Digital Type Series PP4 model PP4005. I am having trouble setting the analog time. When I rotate the crown, the minute hand and hour hand rotate, but when I set the correct...
It's broken. Mine is doing the same thing. Others online have experienced the same defect. I bought mine from woot.com in July and just gave it to my son for Christmas. Check the Seiko website and send it in for repair. It has a 3 yr warranty.
Nov 23, 2009 | Watches
Cant set the second hand to move
The "second" hand on this watch is not actually a 'sweep' second hand, as on other watches.
This is a timer dial. ["Stopwatch 1/5 Second Hand"]
To start/stop this, use the top button (Button "A").
To reset this dial to 12 O'clock, use Button "B", after first stopping it with Button "A".
The "second" hand is the small dial at the 9 O'clock position.
In actuality, you 'could' start this and just not stop it...  Then it would function as a "large second hand". That would be up to the owner. (it might use more battery power though... ?)
Nov 11, 2009 | Pulsar Chronograph Watch
The hour & minute hands on my pulsar nx14-x001 do not move. the second hand quivers, but also does not move. the digital time and other functions are okay. HELP!
Without knowing the model of the watch i would say you need a new battery. It is typical for this style of watch to have two batteries or one lithium battery. In either case the analog movement will drain faster than the digital portion of the watch and will stop working first.
Sep 21, 2009 | Pulsar Watches
Daylight Saving Time will not set correctly
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Oct 09, 2007 | Watches
Not again . . .
Pushing all the buttons at the same time you resets the digital functions. You'll have to reset the time and date, but it will all work again. I don't know why the watch freezes up, but pushing all the buttons at least resets it. I like my watch and this quirk is an annoyance, but it's livable after finding this solution.
Jul 10, 2007 | Timex Expedition® Outdoor Casual...
Watches Logo
42 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
