Question about Envirocare AllStar Javelin 12 Series S-Class Vacuum Motor Filter Hygiene
Javelin vac problems
Vac bag light comes on when hose is atatched
I have a u vac century 400 it shut off bag light stays on all time .
There could be a blockage at the top of the hose, making the impression that the bag is full, take the hose off and check for any blockages. This is a common problem in these makes of vacuum,
Apr 04, 2018 | Century Vacuums
I accidentally vacuumed up a small plastic bag. Now I have no suction. No plastic bag is visible in the canister or the hose. What do I do?
Take my word for it, the plastic bag and / or its' remains is / are somewhere in the hose. Visibility of clear plastic in the dark environs of the interior of the hose is extremely limited if possible at all. Some hoses are corrugated on the inside especially if so on the outside. Without specificity as to brand my best first shot would be to attach the hose to the vacuum cleaners exhaust and try to blow the plastic back out the hose. The exhaust is the port from which the air comes out when everything's working as it should. Even before that, disconnect the hose from the canister, turn on the machine and see if there's any suction at the port where the hose attaches. No suction at the port eliminates the hose as the problem. If your machine will run without a bag, take the bag out and momentarily turn the machine on. Suction with no bag = bad bag. Still no suction= a trip to the vacuum service / sales store
Nov 02, 2017 | Vacuums
Miele s7000
My question is what kind of dirt are you trying to pick up. Regular dirt does not plug up in twenty minutes. If you see dirt flying around that tells me your vac hose or parts that have a suction is plugged up. Take the hose and hose attachments off and make sure there is no dirt inside.If they are clear check the inside of the vac for dirt as well. Check your filter which is back of the vac bag as it may be plugged as well. The filter should come out to be cleaned.
Dec 21, 2017 | Vacuums
Hoover windtunnel dirt finder light stays red. We've cleaned the elbow the roller the hose and have a clean bag. The vacuum is new only had it for 3 months.
I'm not sure about a 3 month old vac, I'd probably go the warranty route. However, for the older vacs thy start getting false positives. The sensor is simply a microphone hooked to a computer chip detecting sounds of dirt entering the bag.
To rig it to start working, you'll need to remove the tool accessory tray and elbow that enters the back of the vac, and attached to the bag. This will reveal the microphone at the elbow, and wire that runs into the bottom area of the vac. When on, a large amount of air comes from the bottom screw and area where the wires enter. My fix was to clean up the microphone contact points a little bit with a screwdriver, and then leave the vac running while putting in dampering in the hole at the bottom, and around the back of the elbow. Cotton balls and electrical tape at the bottom hole, and napkins around the outside of the elbow (wedged between the back of the vac assembly and elbow did the trick). The schematic for the vac is here: http<colon>//www<dot>vacsrus<dot>com/CartGenie/pg_U6485900<dot>asp
Look for micrphone.
May 12, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
I was given an Electrolux vacuum model 1401-B. I would like to download a manual for it. Do you have one? Thanks, Carolyn
Carolyn, The 1401B is one of a family of US built LUX models , now sold by AERUS Electrolux. It shares common info with the MARQUISE, Super J , Olympia and 1205, etc so if you come across a used manual for any of them you will be in good shape.
Try an AERUS Electrolux dealer but the manual may be out of print.Also try a local vac shop
Quick rundown, :
Set the dial at front between medium and fine and don`t adjust, this is the bag fill control, NOT a suction control.
Only use genuine 4 ply filter bags from a pro vac shop, not grocery store grade as this is a vac which filters thru its bag.
Hang the hose for longer life, obstructions can be blown out thru plugging the hose in the blower port under the slide door behind the handle.
Inspect the power head for hair and thread and remove any visible.
When you wheels squeak while vacuming spray the axle shaft behind the neck with a drop of WD 40.
If you feel air venting thru the hose behind the handle or if it is crushed and kinked there or at the vac replace the hose for better suction. The weight of this vac weras out hoses. When the castor below the body cracks and it will, match it with a small SHEPARD castre at the hardware store.
If your rewind is sluggish, pour a tablespoon of talc or baby powder in a tissue and run it up and down the lenght of the vac cord end to end. Then drop the tissue into the vac bag fro fresh scent.....
Enjoy the vac, this one is a great one 30 year plus life span, parts are still available keep it in good repair
Oct 10, 2009 | Vacuums
The beater of my kenmore vacuum won't turn on - the primary light goes on but none of the sensor lights go on.
Kenmore vacs generally have three male contacts at the machine end.Internally when the hoses swivels these contacts run on three brass rings which can also get dirty due to proximity to dirt. They can get dirty or dirt can fall into the corresponding female socket where the hose meets the vac. If you have just changed the bag inspect these connections near the intake port on the vac.
The working LED means you have a partial connection. Also try wiggling and twisting gently at the handle of the hose and where the wand connects to the hose and the power head elbow... you have 4 connections between vac and head
Sep 06, 2009 | Kenmore 22812 Bagged Canister Vacuum
Can't install a bag for my Craftsman 16 gallon shop-vac
Well, good news, you don't need a bag! The trash just settles to the bottom of the bucket and you just dump it out.
I own one of these -- it has many little operational anoyances -- like wheels falling off, lid popping off, etc. If you run into these scenarios and want help on fixes, drop me a line.
Would you please rate my response. I think you'll see some icons at the bottom of the post to enter a rating.
thanks...
Charlie
May 09, 2009 | Shop Vac Vacuums
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
RENAISSANCE HOSE/VAC
THE RENAISSANCE IS KNOWN FOR HAVING PROBLEMS WITH THE CIRCUIT BOARD IN THE HANDLE.YOU'LL NOTICE THAT MODELS THAT CAME AFTER THAT HAD SLIDING SWITCHES. UNFORTUNATELY THE NEW HOSE DESIGN WON'T WORK ON YOUR MACHINE BECAUSE THE CIRCUIT BOARD INSIDE THE MACHINE WAS CHANGED TOO.AERUS MAY OR MAY NOT STILL MAKE THE PARTS YOU NEED. OTHER WISE LOOK ON E-BAY FOR A NEW HOSE.
ELECTROLUX FOOLISHLY REPLACED IT'S FLAGSHIP STEEL MACHINE WITH THIS DESIGN...A FEW YEARS LATER ALL THEY HAD WORTH SELLING WAS THEIR NAME, HENCE THE NEW NAME AERUS.
Mar 28, 2008 | Electrolux Guardian Bagged Canister Vacuum
Envirocare AllStar Javelin 12 Series S-Class Vacuum Motor Filter Hygiene Logo
15 people viewed this question
Top Envirocare Vacuums Experts
Are you an Envirocare Vacuum Expert? Answer questions, earn points and help others
